Thread Number: 82178
/ Tag: Modern Dryers
I love this era Duet Dryer |
Post# 1061937   3/1/2020 at 11:21 (1,510 days old) by stricklybojack (South Hams Devon UK)   |   | |
Just picked up this gas version, I think it only needs a door switch. The previous owner bought a new belt and drum roller kit which I will also install. What is better, one of these or a (real Maytag) Neptune? Really love those Neptune’s as well. |
Post# 1061942 , Reply# 1   3/1/2020 at 11:58 (1,510 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1061943 , Reply# 2   3/1/2020 at 12:06 (1,510 days old) by Spacedogb (Lafayette, LA)   |   | |
I loved my set!!!! I regret getting rid of them but they were a bit too far gone cosmetically for the new house. |
Post# 1061945 , Reply# 3   3/1/2020 at 12:38 (1,510 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The WP is better built in many ways and is larger in capacity.
The WP has a better idler pulley, it has four rollers no cheap plastic slides for drum support, WP also has a blower that will stay attached to the motor and a steel blower housing and lint filter duct so it is less of a fire hazard and a metal lint screen.
All that said I still like the 29" wide WP dryers better overall.
The larger diameter drum lets jeans etc fluff out better and leaves less wrinkles.
The air-flow pattern is just better in the 29" dryer, It is almost unheard of to see any serious lint clogging in the lint-filter housing and blower of the 29" machine.
Post# 1061975 , Reply# 4   3/1/2020 at 17:58 (1,510 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I had this dryer in gas as well, now have a newer version Duet, also gas. Over the years, I've had several 27" WP/KM dryers all gas. It's a very fine dryer for big loads, the combination control units that use temperature and moisture sensing are quite accurate most of the time, but as John points out, the narrower, deep drum tends to roll the load. Larger and bulky items tend to roll into a ball and I get an hour of thumpy tumbling and damp middle at the end.
Dryer balls in this model tend to ride the front of the drum and lazily hang out on top the filter housing. It's better with regular clothing loads, but blankets and like tend to push the balls up front.
Despite the minor gripes, it's a fast and efficient dryer overall and you can't stack a 29" WP. |
Post# 1061984 , Reply# 5   3/1/2020 at 18:58 (1,510 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1062019 , Reply# 6   3/2/2020 at 04:03 (1,509 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 1063911 , Reply# 8   3/20/2020 at 15:15 (1,491 days old) by stricklybojack (South Hams Devon UK)   |   | |
Man was this thing a mess. Here is a before pic to start, lots of mini fires going on in here! All that darkness is a huge blanket of soot laced lint. One dryer wheel support shaft STAT. The old one has a huge flat spot worn into it, and the roller is toast (see pics). The replacement motor and fan assembly are already in. Found a nice deal on eBay and grabbed the whole unit for the price of a cheap used motor; the *door switch* was not the problem like I had hoped! Need to install the new rollers and belt, but that idler pulley in the after cleaning pic is new. This post was last edited 03/20/2020 at 15:37 |
Post# 1066543 , Reply# 9   4/8/2020 at 19:13 (1,472 days old) by stricklybojack (South Hams Devon UK)   |   | |
