Thread Number: 82223
/ Tag: Modern Dishwashers
Miele G7100SCi |
Post# 1062268 , Reply# 1   3/4/2020 at 11:36 (1,485 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Post# 1062337 , Reply# 2   3/5/2020 at 06:32 (1,484 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 1062730 , Reply# 3   3/9/2020 at 15:25 (1,480 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Post# 1062731 , Reply# 4   3/9/2020 at 15:34 (1,480 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Post# 1066726 , Reply# 11   4/10/2020 at 05:51 (1,448 days old) by logixx (Germany)   |   | |
Post# 1066777 , Reply# 13   4/10/2020 at 14:41 (1,448 days old) by Logixx (Germany)   |   | |
Post# 1066796 , Reply# 15   4/10/2020 at 16:23 (1,448 days old) by Logixx (Germany)   |   | |
Post# 1067358 , Reply# 17   4/14/2020 at 16:44 (1,444 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Might be for sensing - quite possibly so - but maybe twice for a few seconds in the prewash and once in the post wash rinse. |
Post# 1067637 , Reply# 20   4/16/2020 at 15:11 (1,442 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
Yes, I had the earlier model with the sensor on the right upper side, no pausing for that one either. I just thought that with this 6xxx one, with the sensor in the sump there might be pausing during the spray, but there is not. |
Post# 1067639 , Reply# 21   4/16/2020 at 15:14 (1,442 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
Correction from my post above. This is a 69XX model and it does have the same optical sensor in the sump that you have, but no pausing the spray. |
Post# 1069769 , Reply# 23   4/28/2020 at 20:48 (1,430 days old) by richnz (New Zealand)   |   | |
The turbidity sensor with the NTC. |
Post# 1069832 , Reply# 24   4/29/2020 at 05:37 (1,429 days old) by Rolls_rapide (.)   |   | |
Wasn't there a turbidity sensor which used two different coloured LEDs (e.g. a red and a green) to get a more accurate reading? I'm thinking it was the likes of Bosch Siemens, but can't be sure. |
Post# 1069884 , Reply# 26   4/29/2020 at 13:13 (1,429 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Running again now with the bit of bleach I have left. Not sure if this is something to call Miele about. I mean, it's just cosmetic, but honestly, on a 1000+ DW after 2 months? Honestly kinda annoyed. |
Post# 1069936 , Reply# 27   4/29/2020 at 18:48 (1,429 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Bleaching helped. Not gonna use the liquid Finish junk anymore except for prewashes. |
Post# 1070271 , Reply# 29   5/1/2020 at 10:46 (1,427 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
The root of all evil is I think the dishwasher tabs. I think they don't contain enough detergent to get a load (and the inside of the dishwasher) really clean. When I use a tab on a dirty load I add some powder, just put it on the door so it is used in the pre-rinse. It really makes a difference, even though the pre-rinse is cold. The dishes are much cleaner than ever before.
Post# 1070272 , Reply# 30   5/1/2020 at 10:48 (1,427 days old) by ozzie908 (Lincoln UK)   |   | |
The dishwasher still cleans everything but the plastic comes out hint of pink and the cutlery rack collects the most colour, However when it gets to a point its bugging me I pop a couple of steriliser tablets in the machine during the prewash and it gets it all off. At around £5 a tub of 100 its not exactly expensive to do either ...
Austin |
