Thread Number: 82272
/ Tag: Wanted to Buy Items
Reliable Opinions-What to Buy |
Post# 1062651 , Reply# 1   3/8/2020 at 20:46 (1,503 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Bear in mind that FL washers are much better overall performers and if you have not been happy with your current FL washer you probably are not using it to best advantage.
Best TL washers are Speed Queen [ the MT machine is poor in durability, skip it ]
SQ makes two very different type TL washers currently, both very durable 25 year type washers.
The TC 5000 series is the traditional machine that has strong agitation that gets big dirty loads clean in 30-40 minutes.
The TR machines are their newer style TL machines, they are quieter and easier on your clothing and spin loads drier like your current FD FL washer. Down side they don't clean big dirty loads nearly as well and the cycle takes 60-80 minutes per load.
If your current washer is still working and you tell us what aspect about it you don't like we may be able to give advice to help you get better performance from it.
