Thread Number: 82287  /  Tag: Vintage Dishwashers
vintage kenmore kds-60
scroll >>> for more items
Post# 1062860   3/10/2020 at 15:41 (1,108 days old) by dennishazard (adams,wi)
my son got a vintage Kenmore kds-60 dishwasher, it works and looks great, but the lower rinse are wont turn when spraying water out of it and I need help trying to figure this out, can anyone help me get started ?
thanks
Post# 1062879 , Reply# 1   3/10/2020 at 22:31 (1,108 days old) by whirlykenmore78 (Prior Lake MN (GMT-0600-CST.))
KDS-60
Is a Hobart model number which would make your machine a KitchenAid made by Hobart(the oldest and largest manufacturer of commercial dishmachines in the world )not a much inferior Kenmore. Pics would help us help you fix it.
WK78
Post# 1062880 , Reply# 2   3/10/2020 at 22:35 (1,108 days old) by aircub (Huntington, AR)
first
take the arm off and see if anything is stuck in there or rumbling around check all the holes see if anything is in one.
hope this works
Darren
Post# 1062886 , Reply# 3   3/11/2020 at 05:47 (1,108 days old) by askolover (South of Nash Vegas, TN)
askolover's profile picture
Mom's KDS17A did the same thing many moons ago.  The spindle the wash arm rotates on had come loose and risen up to the point the wash arm was hitting under the bottom rack track and getting stuck.  I pulled the spindle out, wrapped some teflon tape around it several times and then twisted it back down in there.  It never came loose again and worked fine until the motor died.  I'm sure there was/is a better way to fix it but there was no internet back then (early 1980's) and I just improvised.  As is stated above...a picture is worth a thousand words.
Post# 1062892 , Reply# 4   3/11/2020 at 07:33 (1,108 days old) by chachp (North Little Rock, AR)
I did too on my KDS-15
chachp's profile picture
I don't know what your wash arm support looks like but for many years they were very similar.  Based on Stevet's recommendation I used some Marine Epoxy to temporarily repair the issues with my support.  I used the popsicle sticks to hold it in place until the glue dried.  This worked brilliantly.
I had to glue the spindle in place as well as close up some cracks.  I was lucky to find a new one on eBay but I used the repaired one for two months or so.
