Thread Number: 82373
/ Tag: Classified Ad Finds
Nice Maytag set |
Post# 1064044   3/21/2020 at 15:58 (1,489 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1064045 , Reply# 1   3/21/2020 at 16:02 (1,489 days old) by RP2813 (Sannazay)   |   | |
Post# 1064076 , Reply# 2   3/21/2020 at 20:13 (1,489 days old) by appnut (TX)   |   | |
Post# 1064079 , Reply# 3   3/21/2020 at 20:31 (1,489 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 1064101 , Reply# 5   3/22/2020 at 03:04 (1,489 days old) by Hippiedoll ( arizona )   |   | |
Hello & welcome!
:o) I'm not an expert nor am I familiar with these later Maytag models. But what I can tell you from the pictures is, this washer is; the ex-large capacity, (with infinite water level selector lever) it has 2-speed combination buttons (NORMAL wash/FAST spin, GENTLE wash/Slow spin) 4 water temperature selection buttons (HOT wash WARM rinse) (HOT wash COLD rinse) (WARM wash COLD rinse) (COLD wash COLD rinse) |
Post# 1064102 , Reply# 6   3/22/2020 at 03:21 (1,489 days old) by Hippiedoll ( arizona )   |   | |
Looks pretty dirty in the upper ¼ section.
And I don't know if the porcelain coating around holes in the wash tub is chipped or if it's just dirty around the holes? (See pictures from ad) |
Post# 1064115 , Reply# 7   3/22/2020 at 08:10 (1,489 days old) by kjknit (ohio)   |   | |
Thanks for your input! Yes, the ad says it will probably need a good cleaning. The seller tells me it hasn't been used in a few months. I will ask if it's dirt or damage in those pics. |
Post# 1064130 , Reply# 8   3/22/2020 at 10:37 (1,488 days old) by appnut (TX)   |   | |
Post# 1064134 , Reply# 9   3/22/2020 at 11:05 (1,488 days old) by Yogitunes (New Jersey)   |   | |
I would swap out that agitator for a Load Sensor....cleaning and capacity would greatly improve
CLICK HERE TO GO TO Yogitunes's LINK on eBay
Post# 1064153 , Reply# 10   3/22/2020 at 14:20 (1,488 days old) by RP2813 (Sannazay)   |   | |
Hi Kate,
As Bob mentioned above, this machine has the orbital transmission which results in a shorter, faster agitation stroke than your current machine. Experts here have said it's an improvement over the older type of transmission Maytag used until mid-1987 -- if you can even imagine a Maytag automatic washer that's supposedly more dependable than what earned Maytag its stellar reputation in the first place.
The tub size can be determined by checking the agitator. Standard tub agitators have three holes down the side and larger ones have four holes. The "load sensor" agitators have no holes, but I think by the time they were introduced, Maytag was only producing large tub machines. |
Post# 1065076 , Reply# 11   3/29/2020 at 15:50 (1,481 days old) by kjknit (ohio)   |   | |
Well, that washer purchase seems to be falling through. Any thoughts on the a305 and it's capacity? I am likely bringing this set home now. CLICK HERE TO GO TO kjknit's LINK on Cleveland Craigslist |
Post# 1065090 , Reply# 12   3/29/2020 at 17:08 (1,481 days old) by appnut (TX)   |   | |
Post# 1065114 , Reply# 13   3/29/2020 at 19:37 (1,481 days old) by RP2813 (Sannazay)   |   | |
Post# 1065165 , Reply# 14   3/30/2020 at 08:14 (1,481 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
