Thread Number: 82424  /  Tag: Wringer Washers
Speed Queen wringer washer gasket problem
scroll >>> for more items
Post# 1064757   3/27/2020 at 03:30 (1,101 days old) by abcomatic (Bradford, Illinois)
Hi everyone, I need a gasket for the part of the drain under the washer the the hose connects to. It is a thin round gasket that fits on the top of the drain where it meets up with section that the drain is connected to. A large clamp holds it on to the top section and the clamp has a hand tight screw that clamps and holds it all together. Thanks for your help, Gary
Post# 1065191 , Reply# 1   3/30/2020 at 12:26 (1,097 days old) by Mickeyd (Hamburg NY)
Hi Gary ~
mickeyd's profile picture
Don't they make sheets of this stuff whereby you trace the old gasket over the sheet then cut to fit. Failing that, a very very thin bead of marine sealant, or as a last resort, the spray on Flex stuff has worked tiny miracles here for me. I'm sure you can fashion a new gasket yourself; finding a new one, maybe not.
Post# 1065194 , Reply# 2   3/30/2020 at 13:19 (1,097 days old) by Yogitunes (New Jersey)
yogitunes's profile picture
many hardware stores carry rubber/neoprene gaskets of all sorts of sizes and thickness.....
usually ones for bathroom sinks are around the same sizes needed.....
improvise where you can....
Post# 1066330 , Reply# 3   4/7/2020 at 09:00 (1,089 days old) by polkanut (Wausau, WI )
polkanut's profile picture
I work at O'Reilly Auto Parts, and we sell sheets of gasket material in different thicknesses and composition.
Post# 1066379 , Reply# 4   4/7/2020 at 16:47 (1,089 days old) by abcomatic (Bradford, Illinois)
Thanks for all of your help.
