Thread Number: 82446
/ Tag: Wanted to Buy Items
A710 maytag washer timer |
Post# 1064984   3/28/2020 at 21:42 (1,461 days old) by WaterWitch (Pomona, Calif.)   |   | |
Hello all, does anyone have a timer for a Maytag washer model a710 they would sell?
Post# 1065142 , Reply# 1   3/29/2020 at 23:50 (1,460 days old) by RP2813 (Sannazay)   |   | |
Post# 1065329 , Reply# 2   3/31/2020 at 12:49 (1,458 days old) by WaterWitch (Pomona, Calif.)   |   | |
I ran it on the "permanent press" cycle lastnight, it went through the whole cycle just fine, next I'll try it on the last one, which is a "timed soak". After that I'm going to try to open the timer and spray a silicone lubricant on the main cam. I've never taken a timer apart so this will be a little nerve racking for me.
Post# 1065336 , Reply# 3   3/31/2020 at 14:26 (1,458 days old) by Maytag85 (Sean A806)   |   | |
Post# 1065347 , Reply# 4   3/31/2020 at 15:35 (1,458 days old) by RP2813 (Sannazay)   |   | |
Post# 1065401 , Reply# 5   4/1/2020 at 03:01 (1,457 days old) by WaterWitch (Pomona, Calif.)   |   | |
I selected the "soak only" option. It filled, then agitated a few minutes, then advanced to "off". So that cycle works. Next I turned it to "Timed soak", it agitated then stopped, then agitated again once it hit the 15 mark then stopped. I started it at the 27 mark. So it seems to be cycling correctly so far.
