Thread Number: 82469
Post War Bendix |
Post# 1065362   3/31/2020 at 17:16 (1,087 days old) by Dgray316 (Elizabeth, Illinois )   |   | |
I am looking for a bearing for a post war Bendix washer. The bearing in the unit is ND 77505C25. The specs on this bearing are: ID Bore-25.31mm X OD 51.18mm x 15mm Thick. This bearing was a military grade bearing whuch was also Hyatt Bearing and later bought by GM. The part number Bendix used was 97062 in the tub group. Also I am looking for the seal used in this same group which is part number 97325. Any leads on these parts or the where abouts to purchase these parts please call David Gray at Appliance Archaeologly LLC at 608-371-3619. Someone advised me to ask jetcone or Combo52 which I dont know how to contact them. If you know how to reach them have them look at this post and reach out to me please.I found some on ebay and ordered them and got them today was the right part number but the bearings where the size of 1/2 dollar coin with a bore of 1/2" so I am sending them back.
So the bearing listed on ebay is not correct! Thanks This post was last edited 03/31/2020 at 19:36 |
Post# 1065373 , Reply# 2   3/31/2020 at 18:38 (1,087 days old) by D-jones ![]() |
Post# 1065374 , Reply# 3   3/31/2020 at 18:42 (1,087 days old) by D-jones ![]() |
![]() 2
Post# 1065379 , Reply# 4   3/31/2020 at 20:36 (1,087 days old) by swestoyz ![]() |
Is this bearing on the cylinder side of the tub back, or pulley side? The later parts book shows two different Bendix PNs for either bearing, as well as an updated PN for the seal. Is the MFG PN the same on both bearings for your Bendix?
Either way, it looks like there's a few of the ND77505C25 bearing out on eBay. Ben EDIT - looks like I skimmed over David's comments. Great minds think alike :)
Post# 1065386 , Reply# 5   3/31/2020 at 21:55 (1,087 days old) by bendixmark (Winchester Mass)   |   | |
Would love to see pics of your machine.I have several bendixes. |
Post# 1065406 , Reply# 6   4/1/2020 at 05:11 (1,087 days old) by Slowspin66 (lincoln uk)   |   | |
I’ve just got new seals for a couple of machines I’m doing up from
laundry Pro in Lakeland Florida . I managed to get pump seals and also the bearing seals as a complete kit . Another AW friend directed me to them with part numbers . They are for the Dexter machines but fit the Bendix just great Good luck |
Post# 1065416 , Reply# 7   4/1/2020 at 08:03 (1,087 days old) by swestoyz ![]() |
Post# 1065451 , Reply# 8   4/1/2020 at 11:52 (1,087 days old) by Slowspin66 (lincoln uk)   |   | |
![]() 2
This is the one
Post# 1065453 , Reply# 9   4/1/2020 at 11:54 (1,087 days old) by swestoyz ![]() |
Post# 1065521 , Reply# 10   4/1/2020 at 19:01 (1,086 days old) by bendixmark (Winchester Mass)   |   | |
Does a dexter pump seal fit a 1940s bendix?I may be needing some of those for the bendixes I have.For that matter I have a Dexter but it is gravity drain and I was told there is a pump conversion kit and I need to find one of those. |
Post# 1076237 , Reply# 11   6/7/2020 at 18:05 (1,019 days old) by Slowspin66 (lincoln uk)   |   | |
Hi I’ve used the Dexter pump seals and they work great about $15 a piece
