Thread Number: 82538
/ Tag: Vintage Dishwashers
Maytag MDB5000 Dishwasher acting strange |
Post# 1066164 , Reply# 1   4/6/2020 at 03:16 (1,082 days old) by askolover ![]() |
Post# 1066172 , Reply# 2   4/6/2020 at 06:15 (1,082 days old) by vacerator (Macomb, Michigan)   |   | |
Very heavy machines. I had a portable base model. I guess the solid wood top was part of the heft, but the thick steel base was also. I liked the fan drying on it. |
Post# 1066184 , Reply# 3   4/6/2020 at 07:36 (1,082 days old) by combo52 ![]() |
![]() Did it drain as soon as you tried turning the timer to a drain cycle earlier in the cycle ?
If not the motor probably overheated, if it only skips the drains at the end of the cycle you may have a bad timer.
Parts can still be found for this DW, I have several good used pump&motors for these DWs if you need one $100+ shipping.
In any event try running the machine again, I have seen motors overheat when people got carried away adding sound proofing insulation under the DW.
