Thread Number: 82790
internal water heater |
Post# 1069659 , Reply# 1   4/28/2020 at 08:36 (1,458 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Sanitize with Oxi is used on Whirlpool corporation machines that either don't have a heater (FLs) or on machines that can't reach the required temps for normal Sanitize cycles (TLs). Machines with Steam do have a heater though, independent of Sanitize cycle. |
Post# 1069670 , Reply# 2   4/28/2020 at 09:22 (1,458 days old) by agiflow3 ()   |   | |
The Whirlpool 6620 has a heater and a steam function. I have the machine. |
Post# 1069673 , Reply# 3   4/28/2020 at 09:24 (1,458 days old) by agiflow3 ()   |   | |
If the Whirlpool machines says just sanitize and there is no oxi designation then it has a heater |
Post# 1069675 , Reply# 4   4/28/2020 at 09:29 (1,458 days old) by roscoe62 (Canada)   |   | |
Thank You, does the whirlpool rinse towels well with the towel cycle? |
Post# 1069691 , Reply# 5   4/28/2020 at 11:18 (1,458 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1069713 , Reply# 6   4/28/2020 at 13:18 (1,457 days old) by appnut (TX)   |   | |
I think there is more to this than what meets the eye. I conjecture the there is difference in the cycle software on the 5620 vs. the 6620, hence why there is a differentiator of "with oxi" and one that doesn't have the designate "with ox" I'd only buy one that didn't have "with oxi" on the front next to Sanitize. I can tell you the KWH rating on the 5620 and 6620 is less than the 8620 & 9620 whirlpool models. The latter two have the same KWH rating on Energy Star tag as is found on my 2011 WFW97HEX Duet. I will always select a model with higher KWH rating as that means more cycles with the onboard heater being used. |
Post# 1069848 , Reply# 8   4/29/2020 at 08:03 (1,457 days old) by roscoe62 (Canada)   |   | |
To all for your input, appreciated. |
