Thread Number: 82935
AEG TOP LOADER SOUNDING LIKE AN AIRCRAFT IN DEPARTURE |
Post# 1071621 , Reply# 1   5/9/2020 at 15:58 (1,445 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1071630 , Reply# 2   5/9/2020 at 16:18 (1,445 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Grinding sounds are usually bearings. Described as sounding like gravel, a plane takeing off, trains going by etc. For what ever reason on their TLs the bearings are actually replaceable and are around 100€ for both sides. |
Post# 1071729 , Reply# 3   5/10/2020 at 02:43 (1,445 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Bearings. Period. |
Post# 1071733 , Reply# 4   5/10/2020 at 04:04 (1,444 days old) by richnz (New Zealand)   |   | |
And spin the drum pulley can you hear the sound more clearly? Youtube has a couple of videos. A quick google of "aeg toplader bearing" brought some up. It looks to be a fun project. |
Post# 1071736 , Reply# 5   5/10/2020 at 05:26 (1,444 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1071740 , Reply# 6   5/10/2020 at 06:58 (1,444 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1071763 , Reply# 7   5/10/2020 at 11:07 (1,444 days old) by gsh1972 (Italy)   |   | |
Thanks all. Is this a simple operation? There is a big concrete weight attached to the drum and i wonder if it is necessary to remove it when changing bearings. Thanks again. |
Post# 1071807 , Reply# 8   5/10/2020 at 15:25 (1,444 days old) by gsh1972 (Italy)   |   | |
Don't worry I found a guy that showed me how. I can do that!! |
Post# 1071915 , Reply# 9   5/11/2020 at 04:55 (1,443 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1072076 , Reply# 11   5/12/2020 at 05:24 (1,442 days old) by richnz (New Zealand)   |   | |
requires an odd tool to remove or you need to be creative using other tools in order to spin it off. I agree that its so sad that AEG in the past made magnificent appliances. I wonder if the engineers moved to Miele? |
