Thread Number: 83018
toughs on new duet washer from whirlpool? |
Post# 1072941   5/17/2020 at 06:51 (1,437 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
hello to all aw members what are everyone toughs on the new whirlpool duet washer with matching dryer?
Post# 1072953 , Reply# 2   5/17/2020 at 09:15 (1,437 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
agiflow do you think if for x reason my mom and i had to replace or current set i should reccomend those to my mom? and that comes to my other question what are the water temp and how long can the drying time for the dryer be set if load needs a shorter drying time exemple a small load and do the washer have a light inside if washer is install in a space where there not much light? i apoligize for all my questions
Post# 1072959 , Reply# 3   5/17/2020 at 10:10 (1,437 days old) by appnut (TX)   |   | |
Post# 1072969 , Reply# 4   5/17/2020 at 11:50 (1,436 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What is the new name for the duets? What is the default temp for each cycle? For example, the normal/regular cycle on washer/matching dryer. |
Post# 1073000 , Reply# 6   5/17/2020 at 15:39 (1,436 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1073005 , Reply# 7   5/17/2020 at 15:55 (1,436 days old) by appnut (TX)   |   | |
My 9 year old Duet spins in-between wash and rinses on all cycles except delicate or handwash. If a current machine didn't do interim spins on Normal Cycle, I'd never use it anyway. That's why they call it Normal, people are too stupid to know what goes on in their washers and complain about poor rinsing. I use cycles for what I expect them to do, not what the label tells me. |
Post# 1073010 , Reply# 8   5/17/2020 at 16:29 (1,436 days old) by agiflow3 ()   |   | |
On the normal cycle it will spin between the wash and the first rents but just go right into the second rinse |
Post# 1073018 , Reply# 10   5/17/2020 at 17:19 (1,436 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1073034 , Reply# 11   5/17/2020 at 19:31 (1,436 days old) by appnut (TX)   |   | |
Post# 1073043 , Reply# 12   5/17/2020 at 20:19 (1,436 days old) by agiflow3 ()   |   | |
Yes Bob if I did all the different combinations I could probably have found out but as it is now my machine sits off to the side waiting to be picked up |
Post# 1073052 , Reply# 14   5/17/2020 at 21:05 (1,436 days old) by appnut (TX)   |   | |
Post# 1073055 , Reply# 15   5/17/2020 at 21:17 (1,436 days old) by agiflow3 ()   |   | |
How rough could baffles in a front load actually be ? You have the cushioning effect of the water ? |
Post# 1073065 , Reply# 16   5/17/2020 at 21:53 (1,436 days old) by bradfordwhite (central U.S.)   |   | |
I love my WP Duets. I'd like to get these too. They have the drawer which gives access to the pump clean out and the detergent auto feeder option.
I've also seen these at Lowes as well for like $600
Post# 1073083 , Reply# 18   5/17/2020 at 23:41 (1,436 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1073113 , Reply# 19   5/18/2020 at 06:37 (1,436 days old) by agiflow3 ()   |   | |
I'm moving in 3 weeks and I already have machines in place. |
Post# 1073115 , Reply# 20   5/18/2020 at 06:40 (1,436 days old) by agiflow3 ()   |   | |
The load and go is a 40 load dispense on the WFW6620. It is a dispenser that sits inside the bottom pull out drawer. I believe it is smaller on the 5620. |
Post# 1073120 , Reply# 21   5/18/2020 at 07:27 (1,436 days old) by appnut (TX)   |   | |
Post# 1073128 , Reply# 22   5/18/2020 at 09:44 (1,436 days old) by agiflow3 ()   |   | |
The WFW560CHW doesn't have a steam cycle. The WFW5620HW has the regular sanitize and a steam clean option. The only difference between this and the 6620 is that the 5620 has a smaller load and go dispenser. |
Post# 1073154 , Reply# 23   5/18/2020 at 13:11 (1,435 days old) by SudsMaster (SF Bay Area, California)   |   | |
