Thread Number: 83111
Maytag A512 Shakes and Moves |
Post# 1074192 , Reply# 1   5/25/2020 at 00:54 (1,033 days old) by qsd-dan ![]() |
![]() 2
Damper pads are getting dry. You may have caught it in time if the (bad) vibrations recently began and can get away with just lubing the pads. If not, the pad(s) get ripped off the base via friction and the aluminum damper loses out in the metal hardness scale. Remove the front panel and use a flashlight for inspection.
CLICK HERE TO GO TO qsd-dan's LINK |
