Thread Number: 83294
Question about Maytag Suds Saver use |
Post# 1076131 , Reply# 1   6/7/2020 at 01:07 (1,024 days old) by ea56 ![]() |
![]() We had a MOL 62’ Whirlpool with a suds saver and Mom always loaded the next load before returning the saved sudsy water to the washer from the laundry tub it was being held in and the washer added any additional water necessary to the level set on the controls.
But that being said, when you use a wringer washer you add the clothes the the already water filled tub with the agitator running and it pulls the clothes under the water without having to push them in, so I imagine that a Maytag automatic with a sud saver and a Gyrator would work the same way.
Eddie |
Post# 1076158 , Reply# 2   6/7/2020 at 06:52 (1,024 days old) by RE563 ![]() |
My Mom has a Maytag A512 With suds Savor. What she does do is she puts a paint stir stick in to hold the lid switch in so the washer well run with the lid open. After the water reaches the small load level (appox.) she will start adding clothes slowly. By the time it has completed pumping all the water back in from the tub, the load is in and she then will set it to the desired wash time and will add any water if needed.
Hope this helps. |
Post# 1076193 , Reply# 4   6/7/2020 at 12:41 (1,024 days old) by Tomturbomatic ![]() |
Thank you all. |
