Thread Number: 83313
/ Tag: Classified Ad Finds
Something Notable in Austin TX |
Post# 1076326   6/8/2020 at 10:23 (1,416 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1076332 , Reply# 1   6/8/2020 at 11:34 (1,416 days old) by appnut (TX)   |   | |
Post# 1076337 , Reply# 2   6/8/2020 at 11:51 (1,416 days old) by pulltostart (Mobile, AL)   |   | |
Post# 1076341 , Reply# 3   6/8/2020 at 12:33 (1,416 days old) by bradfordwhite (central U.S.)   |   | |
I agree Bob, that's one of the worst I've seen for staining.
The worst KM dryer I've seen was a gas model with limit switch that cut out too high AND the rollers that needed to be replaced 2 decades ago so that the drum sank and the edge wore a hole in the back wall of dryer. That's wasn't fixable. lol. How they used it all that time with the noise and the metal shavings in their clothes..... ? |
Post# 1076347 , Reply# 4   6/8/2020 at 13:35 (1,416 days old) by DADoES (TX, U.S. of A.)   |   | |
RJ's Neptune dryer found for free on CraigsList in Nov 2006 (serial Nov 2000) had been run with bad drum slides and/or rollers to destruction, until the edge of the drum split and tore through the drum front. I found the edge of the drum jammed through the front behind the door shroud like razor wire. Parts were available so I repaired it. Front $55.99, drum $69.99 via SearsParts. |
Post# 1076365 , Reply# 5   6/8/2020 at 15:13 (1,416 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1076385 , Reply# 6   6/8/2020 at 16:52 (1,416 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1076393 , Reply# 7   6/8/2020 at 17:37 (1,416 days old) by DADoES (TX, U.S. of A.)   |   | |
I have a Catalyst (the matching dryer is running at the Ave A rental with a VMW) that is still on hold until I get up the gumption (and decide what to do about living space for it) to do a bit of transmission service and the reassembly for a complete mechanical rebuild on it. I'd be interested in the various rare parts (console, water valve assembly, drain valve) but I suppose someone else would have more fun with it intact. |
Post# 1076421 , Reply# 8   6/8/2020 at 21:25 (1,416 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
We have a customer that still has this pair with a gas dryer. The washer like other electronic WP-KMs catalyst machines often have control problems, the dryers were more reliable.
This is what happens if you don't take that darned blue plastic off the consoles, the blue tint will spread to the dryer drum, LOL
Post# 1076484 , Reply# 9   6/9/2020 at 16:36 (1,415 days old) by goatfarmer (South Bend, home of Champions)   |   | |
