Thread Number: 83425
Hose leaking help please |
Post# 1077490 , Reply# 1   6/17/2020 at 05:35 (1,380 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1077492 , Reply# 2   6/17/2020 at 06:13 (1,380 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
The picture above is for your waste hose ? so you have pushed the rhs over the black plastic adaptor and clamped it and the LHS looks like you have pushed the hose inside and clamped it ?
In which case it looks like it could leak from the LHS as its clamped on the plastic connector ? difficult to see it ? You need an adaptor that you push both pipes onto to get a tight fit and then clamp them both sides like the picture below.. BUT if you say its still leaking when the machine is filling then it sounds like its the cold fill smooth grey cold water fill pipe that needs tightening and is the issue as well..
