Thread Number: 83452
/ Tag: Modern Dishwashers
Port.WP DW WON'T DRAIN... NEED HELP...SUGGESTIONS |
Post# 1077718 , Reply# 1   6/18/2020 at 15:12 (1,404 days old) by appnut (TX)   |   | |
Post# 1077722 , Reply# 2   6/18/2020 at 15:41 (1,404 days old) by washdaddy (Baltimore)   |   | |
Thanks for the input Bob. I'd you are referring to the filters that you can remove from inside the DW we have done that and made sure they were clean. are there any other filters I should be aware of that are under the tub? |
Post# 1077723 , Reply# 3   6/18/2020 at 15:50 (1,404 days old) by washdaddy (Baltimore)   |   | |
Post# 1077724 , Reply# 4   6/18/2020 at 15:52 (1,404 days old) by washdaddy (Baltimore)   |   | |
Sorry for the double post gang! |
Post# 1077757 , Reply# 5   6/18/2020 at 19:06 (1,404 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Rick, It would be really helpful if you [ and anyone else ] would post a model # when asking for help with an appliance..
If it is a newer style WP filter wash DW with a separate electric drain pump lay the DW over and remove the drain pump and check for a piece of broken glass, plastic Etc caught in the pump housing, also check for damaged impeller.
Make sure the drain hose is really clear and not kinked anywhere, there is a Check valve on the end of the hose near the pump that can clog, the other common place for is in the uni-cupple that attaches to the faucet [ if it is clogged at the UC when the DW goes to drain you can usually hear a restricted noise at the UC ]
A clogged filter will not affect draining because the water does not drain through the filter screen when draining.
If you can not find any problem replace the drain pump. The DP just twist locks in and out, no tools required.
Post# 1077765 , Reply# 6   6/18/2020 at 19:36 (1,404 days old) by washdaddy (Baltimore)   |   | |
MODEL# WDP350PAAW6 SER# F606061 I've been on this site long enough to know that I should have given everyone that info. My apologies for my transgression. (hehehe) |
Post# 1078555 , Reply# 8   6/24/2020 at 19:42 (1,398 days old) by appnut (TX)   |   | |
