Thread Number: 83515  /  Tag: Vintage Dryers
Dryer timer cap broke - can I fix it easily?
scroll >>> for more items
Post# 1078370   6/23/2020 at 11:53 (1,008 days old) by Allyn (Usa)
I have a Maytag Atlantis dryer. Model # MDE7400AYW serial # 19727328CJ.
While pulling the timer knob to start the cycle, it broke and came off completely. The dryer still works when I use players to pull the plastic middle part connected to the timer. I think I only need the plastic part to be replaced but i cannot find only that part. Is there a way I can recreate this or replace just the plastic part? Or must I buy a whole new timer? Thank you for helping.
Post# 1078378 , Reply# 1   6/23/2020 at 12:26 (1,008 days old) by coldspot66 (Plymouth, Mass)
You will have to replace the timer
Post# 1078440 , Reply# 2   6/23/2020 at 22:56 (1,007 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
Broken timer shaft.
combo52's profile picture
You can just bypass the start contacts in the timer and then it will just when you turn the timer to the setting desired and close the dryers door.
