Thread Number: 83522  /  Tag: Vintage Dishwashers
Moen Faucet Issues Hotpoint Sink/Dishwasher Combo from 50's
scroll >>> for more items
Post# 1078444   6/23/2020 at 23:29 (1,007 days old) by frank1492 (Worcester)
Hello All,
Still in operation! The problem is in the original Moen vertical mount single handle faucet. This was an early Moen that did *not* have a cartridge. Although the faucet shuts off perfectly the lever moves with great difficulty. Can anyone suggest a lubricant?? WD-40 works at first but then gets sticky. Help much appreciated.
Frank
Post# 1078467 , Reply# 1   6/24/2020 at 05:16 (1,007 days old) by arbilab (Ft Worth TX (Ridglea))
arbilab's profile picture
I'd recognize that, had HP electric sink in 1953.
Never had it apart though (I was barely 8yo at the time).  I use a light film of silicone grease on faucet o-rings to make them move smoothly.  But again, don't know the internals of the Moen or even how it comes apart.
I know you can't use petroleum on rubber, kinda dissolves it.
Post# 1078471 , Reply# 2   6/24/2020 at 06:24 (1,007 days old) by tolivac (greenville nc)
At the transmitter plant use the silicone grease on all rubber pipe gaskets and tube seal gaskets for steampipes and water supply pipes in the transmitters.Some of the tubes are vapor-steam cooled.Vaporize water in the tube anode boiler to steam for more efficient cooling than pumpted water.Some tubes use pumpted water cooling-use the silicone grease on their seals,too.
