Thread Number: 83624
/ Tag: Modern Dishwashers
dishwasher residue/film/dust |
Post# 1079575 , Reply# 1   7/2/2020 at 11:35 (1,365 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1079583 , Reply# 3   7/2/2020 at 14:09 (1,365 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1079584 , Reply# 4   7/2/2020 at 14:16 (1,365 days old) by trae (Baton Rouge)   |   | |
we're trying powder now. no dishes. just racks and jetdry |
Post# 1079625 , Reply# 6   7/2/2020 at 23:05 (1,364 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1079672 , Reply# 7   7/3/2020 at 10:52 (1,364 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Run these two tests to see if DW is working properly.
Take a tall glass and smear peanut butter inside it and place in upper rack, all PNB should be washed away after a complete cycle.
2nd test, put a 4 cup measuring cup in the lower rack sitting up-right and start DW, when you open the door after about 5 minutes after starting the cycle the measuring cup should be full of water.
If DW failed either test you either have a fill problem [ usually a bad inlet valve ] or a circulating pump problem.
This is why it is always best to put dishes in a DW covered with food, this way you will know immediately if the dishes you are removing from your DW have been washed and rinsed correctly, other wise you may be eating off dishes that are not washed and rinsed and may be covered with detergent and wetting agent.
Post# 1079694 , Reply# 8   7/3/2020 at 15:24 (1,363 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1079699 , Reply# 10   7/3/2020 at 16:21 (1,363 days old) by Labboy (SD, CA)   |   | |
Post# 1079708 , Reply# 11   7/3/2020 at 18:40 (1,363 days old) by trae (Baton Rouge)   |   | |
it's definitely filling properly - right up to the bottom of the float. not quite an inch at the deepest point. i checked that multiple times. |
Post# 1079714 , Reply# 12   7/3/2020 at 20:04 (1,363 days old) by DADoES (TX, U.S. of A.)   |   | |
Add a quart of hot water after each fill through a cycle the next time you run a load of dishware or repeat the powder detergent test, see if it helps. Also just to say, the float does not control the fill level. Fills are timed. The float only comes into play to shut off the inlet valve in an overfill situation such as after an imcomplete drain due to a pump obstruction. It doesn't stop an overflow if the inlet valve hangs open. |
Post# 1079748 , Reply# 13   7/4/2020 at 06:46 (1,363 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1079853 , Reply# 15   7/4/2020 at 23:57 (1,362 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What's new about the circulation pumps from the older point voyager platforms? |
Post# 1079924 , Reply# 16   7/5/2020 at 15:49 (1,361 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1080176 , Reply# 17   7/7/2020 at 12:14 (1,360 days old) by SudsMaster (SF Bay Area, California)   |   | |
