Thread Number: 83666  /  Tag: Vintage Automatic Washers
No Gentle Speed Whirlpool Washer
scroll >>> for more items
Post# 1080061   7/6/2020 at 15:44 (994 days old) by Washerlover (The Big Island, Hawai’i)
washerlover's profile picture
My 1974 (?) Whirlpool washer model LFA5700G1 will not engage in gentle agitation or spin.  Normal cycle works fine.  Gentle/Knit/Perm Press will fill but only buzzes when trying to agitate and spin.  Neutral drain works fine since it’s Normal speed.  Any ideas?
Thanks.
Post# 1080072 , Reply# 1   7/6/2020 at 16:41 (994 days old) by imperial70 (MA USA)
I am no expert. Just wanted to say that's a great looking Whirlpool. I always loved the shift from gentle wash to neutral drain. Very dramatic. :-) Could it be a motor problem with your machine?
Post# 1080073 , Reply# 2   7/6/2020 at 16:45 (994 days old) by DADoES (TX, U.S. of A.)
dadoes's profile picture
L"F" series is 1978-79 model-year.  Check for a wire burned or loose on the motor.  Or bad timer.  Or bad motor.
Post# 1080112 , Reply# 3   7/6/2020 at 20:21 (994 days old) by Supersurgilator (Indiana)
Beautiful machine!! I agree my first thought is something is going on with the low speed in the motor windings.
Post# 1080125 , Reply# 4   7/6/2020 at 23:52 (994 days old) by toploadloyalist (San Luis Obispo, CA)
Just curious, is the cool-down drain (Permanent Press and Knit cycles) low speed?
Post# 1080144 , Reply# 5   7/7/2020 at 07:10 (993 days old) by Yogitunes (New Jersey)
yogitunes's profile picture
as a quick test, switch the wires on the motor terminals....
set machine to normal, does the motor run on slow speed now?
no....bad motor
yes...timer or wiring issue
Post# 1080154 , Reply# 6   7/7/2020 at 09:47 (993 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
Reply # 5
combo52's profile picture
Good suggestion Martin, Switch the orange and blue wires leave the white wire alone.
John L.
Post# 1080168 , Reply# 7   7/7/2020 at 11:39 (993 days old) by Maytag85 (Sean A806)
maytag85's profile picture
I had this issue a couple of months ago on my Kenmore portable washer and ended up having to replace the motor since the low speed was no longer working and mad a funny burning smell when running
Post# 1080371 , Reply# 8   7/8/2020 at 18:52 (992 days old) by toploadloyalist (San Luis Obispo, CA)
Permanent Press agitation downshift
Is it at the 6 minute mark in the Permanent Press cycle where the agitation downshifted from high to low speed?
