Thread Number: 83741
MVWP575GW tub doesnt fill tub on FULL cycle |
Post# 1080988 , Reply# 1   7/14/2020 at 10:42 (1,379 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1080991 , Reply# 2   7/14/2020 at 10:55 (1,379 days old) by ea56 (Cotati, Calif.)   |   | |
You’re showing the water level on an empty tub (no clothes in it). Have you checked to see what the water level is if you’ve loaded a full tub of laundry, let it fill and begin the wash cycle? It may very well only fill to the 13” level because the tub is empty and the machine senses this.
My Roper RTW4516FW fills to the VERY top if I select a deep fill cycle and the tub is loaded to the top. I believe that this washer is similar to yours, albeit a much less expensive model, but they are both made by Whirlpool and both have the same dual action agitator, only mine has a porcelain tub.
Is the machine washing your laundry to your satisfaction? Thats the true test of whether or not its functioning properly.
Eddie |
Post# 1080992 , Reply# 3   7/14/2020 at 10:58 (1,379 days old) by DADoES (TX, U.S. of A.)   |   | |
You're getting the same fill levels with clothes loaded? SearsPartsDirect - Diagrams for MVWP575GW0 The water level pressure tube is in the wiring harness on the "Basket and Tub Parts" diagram ... #25. It connects to the outer tub and to the control board in the console. |
Post# 1080994 , Reply# 4   7/14/2020 at 11:17 (1,379 days old) by appnut (TX)   |   | |
Post# 1080998 , Reply# 5   7/14/2020 at 11:35 (1,379 days old) by ea56 (Cotati, Calif.)   |   | |
Post# 1081048 , Reply# 9   7/14/2020 at 16:46 (1,378 days old) by eronie (Flushing Michigan)   |   | |
Do not wash in cold water! |
Post# 1081053 , Reply# 11   7/14/2020 at 17:19 (1,378 days old) by PinkPower4 (USA)   |   | |
Sorry. You have to start AND THEN PAUSE normal cycle to add your own hot water. Hope that makes sense. |
Post# 1081065 , Reply# 12   7/14/2020 at 18:14 (1,378 days old) by joelschl (Melbourne FL)   |   | |
@eronie. I do not ever wash in cold water. I only set that setting to cold water for my tests |
Post# 1081141 , Reply# 13   7/15/2020 at 10:49 (1,378 days old) by eronie (Flushing Michigan)   |   | |
Ok just saw where the knob is in pic. |
