Thread Number: 83922
Fastest Stackable Washer/Dryer |
Post# 1082755 , Reply# 1   7/27/2020 at 23:06 (1,367 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
If you are looking for a stacked commercial grade W/D Stack unit The Speed Queen Front load stack is the only way to go. It is the same machine as their coin-op stack with better cycle controls and no coin meter. This is the only true commercial laundry stack available for home use. Not to mention it is built to run 25,000 cycles in a commercial setting and will easily last 30 years. Another nice thing is that it is made in the USA! WK78 |
Post# 1082777 , Reply# 3   7/28/2020 at 05:47 (1,366 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
We stay in a 5 unit bed and breakfast owned by an engineer--he analyzed his choke points and realized it was trying to get by with a single washer and dryer. He invested in a second (normal consumer grade) and did far better without that choke point. Your case isn't identical, but it sounds like your choke point is your linen stock---presuming you've got a week between rentals, double your linen stock then do the laundry at your convenience through the week. I notice this when we're leaving our condo, there's a last-day backup of laundry...
Post# 1082783 , Reply# 4   7/28/2020 at 06:48 (1,366 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The gas is a little faster, tase machines will do 22 pound loads in about an hour, that's more than 20 really large towels or about 30 regular bath towels.
I A compact 240 volt dryer has a much smaller heating element and will be slower, the Frigidaire stack you have has a 4,500 heater, the SQ has a 5,400 watt heater, also check if you are in a 208 volt area in which case the heater in the FD will only be putting out 3,375 watts.
If you are in a 208 V area SQ sells a 208 element so you get full speed if you stay with an electric dryer.
The SQs will do almost twice as large a load as the FD stack will as well, we work on at least 6 of those FD stacks a week, they are crude but work ok in light use situations like one BR condos with no more that 2 people.
