Thread Number: 83948  /  Tag: Modern Automatic Washers
Spin Dryer
Post# 1082954   7/29/2020 at 14:54 (1,356 days old) by chetlaham (United States)
chetlaham's profile picture
Why are there setups where there is a tumble washer and a spin-dryer? Why can't the tumble washer do a spin dry?
Post# 1082960 , Reply# 1   7/29/2020 at 16:33 (1,356 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
launderess's profile picture
Many older h-axis washing machines final spin topped out at 800 to 1100 rpms. Earlier such machines had even lower spin speeds of around 400 or less. Needless to say this results in plenty of water being retained in wash resulting in long drying times.
American housewives and even laundries never bothered much about high levels of residual moisture in wash once tumble dryers came on scene. You simply baked all that water out of laundry. Given relatively inexpensive energy prices in USA no one was bothered, until Congress gave EPA a stick to beat people over head with.
Energy prices for much of Europe tend to be more dear than USA, thus dryers aren't or weren't common. People just hung up wet wash on a horse, airier, outdoors, etc.. and waited for things to drip dry.
Either using a dryer or line drying spinning out more water in a spin dryer results in faster drying times.
It varies by type of item, but wash taken from my Miele (spun at 1100 rps) dries about ten percent or more faster when bunged in spin dryer for about three minutes. You notice difference especially with thick and absorbent things like bath linens, blankets, etc....
Less long winded answer is there are two main ways of removing moisture from wash; you can extract it out (spin drying) or evaporate (line or machine drying). The more you do of the former less of it is needed with latter, and in case of using energy to generate heat that means less of that is used as well.
Post# 1082963 , Reply# 2   7/29/2020 at 16:54 (1,356 days old) by chetlaham (United States)
Excellent explanation!
Why did early front loads only spin to 400rpm?
Post# 1082964 , Reply# 3   7/29/2020 at 17:02 (1,356 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
Will leave that for others to explain....
FWIU it simply came down to various things such as motors with enough power, suspension systems to handle forces generated, and or technology available at time.
Keep in mind Bendix had tons of patents for H-axis washers locked up. If others wanted to make similar machines they either had to pay Bendix for use of their patents, or find ways around that didn't violate.
Even early twin tub washers by Easy, General Electric, and others with separate spin dryer compartments didn't spin very fast. Their spin speeds were around 600 to 700 rpms, same as many automatic top loaders that would follow.
Some of the rest you can glean from this article about hard mount commercial washers. bandctech.com/commercial-laundry...
Also as always it helps to check the archives: www.automaticwasher.org/c...
Here is a patent held by Alliance Laundry Systems for load imbalance and extraction speed selection: patents.google.com/patent/US2007...
Post# 1082967 , Reply# 4   7/29/2020 at 17:15 (1,356 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
Here is a video from a "Wash In" showcasing a members new to him Philco-Bendix washer coupled with American Motex extractor.
You can see that the spin dryer removes quite a bit of water from finished wash.
There was a time extractors by Bock and others were routinely found in American laundromats. Injuries including one that resulted in death of a young child (or was he just severely maimed?) resulted in Bock being sued to nearly out of existence.
Some laundromats still offered extractors, but many took them out of service either by choice or by insurance mandate.
Post# 1082968 , Reply# 5   7/29/2020 at 17:28 (1,356 days old) by chetlaham (United States)
How fast does that Philoc Bendix spin? Did the lack of electronics play a role?
I know newer machines have sensors and do all sorts of load distribution while older machines would just engage a 4 pole motor...
Thanks for the info, I will start reading/digesting it.
Post# 1082969 , Reply# 6   7/29/2020 at 17:36 (1,356 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
My newish AEG Lavamat is streets ahead of older (from 1990's) Miele washer in terms of spinning.
Lavamat like many modern front loaders isn't just controlled by "electronics", but entire washer pretty much runs off the motherboard. Everything from motor to drum movements can be controlled resulting in less unbalanced loads and smooth spinning.
The Miele OTOH will make a few attempts at balancing a load before it spins, but when timer moves to "SPIN" that is what machine will do regardless. This even if it means banging, clanging and shifting out of place. Later Miele washers got an out of balance detection system that would stop machine in case of severe issues.
Post# 1082970 , Reply# 7   7/29/2020 at 17:53 (1,356 days old) by chetlaham (United States)
I want timers lol.
Post# 1082971 , Reply# 8   7/29/2020 at 18:02 (1,356 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
If you're refering to the The Laundry Alternative Niagara (and now the promotional combo that comes a Niagara and a Ninja spin dryer at a reduced price)
The answer is very simple, as I created the concept and designed both products.
PORTABILITY.
1) Any washer that spins require a complex suspension system, being HATL, it would also require stabilizers (concrete blocks) this adds A LOT of weight to any washer.
2) We needed a solution that is extremely lightweight, as the sales are 100% online. We can't ship anything above an specific limit, unless we use white glove service, that is absurdly expensive.
3) The target consumer lives in small apartments with no dedicated space and hookups for a washer. The solution has to be convenient to use in a bathroom or kitchen, connected to a regular sink faucet and after use, the washer has to be portable enough to be repositioned in a closet. You can't to that with a washer that heavy. Think of an old lady with weak arms moving a 100+ lbs front load washer. The Niagara is 19lbs, the same old lady can lift the washer with one hand or glide it without scratching the floors.
Also, the product MSRP has several limitations. if we add a spin cycle, it would cost basically the same as a high end front load washer ($900+) and if we add the shipping cost, we would reach average ($1500) If you can afford $1500 on a washer, you probably wouldn't live in a tiny home.
We are also developing a HATL model that spins at 1650rpm (and also a version that dries, including a GAS drying version), full of bells and whistles, including Alexa/Siri/Cortana/ integration, targeted to luxury market (of course it will cost a fortune)
Put everything together. we have the Niagara.
And regarding patents... the HATL wash system patent expired decades ago and it's public domain. (a top load washer that has a rotating drum and the drum has an opening to add and remove clothes from the top). We can (and did) patent specific details and designs pertinent to that model.
Post# 1082974 , Reply# 9   7/29/2020 at 18:24 (1,356 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
Post# 1082980 , Reply# 10   7/29/2020 at 18:58 (1,356 days old) by chetlaham (United States)
Your last link is rather eye opening. Double the RPM and you almost half the energy needed to dry a load.
Post# 1082981 , Reply# 11   7/29/2020 at 19:02 (1,356 days old) by chetlaham (United States)
Washer Without Weights
You know... one could in theory build a combo with low spin speed and rely on the drying portion of the cycle to do most of the work. Simple timer for control. Would be an interesting concept though energy heavy.
Post# 1082983 , Reply# 12   7/29/2020 at 19:10 (1,356 days old) by chetlaham (United States)
Niagra
@Thomas: Do you have the tech sheet/cycle sequence for this machine? Any pics of the internals? What type of motor does it use? Must know more, way to cool!!!!!!!!
Post# 1082988 , Reply# 13   7/29/2020 at 19:47 (1,356 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
Actually no, you can't...
Sometimes the niagara walks half inch tothe side (and comes back as soon as the drum reverses) during the wash (washer full of water, heavy) because the weight isn't enough and also because there's no suspension system.
Without a suspension, even tumbling with no water could make the washer jump.
During the product development, i tried to make it spin at super low speed, only to remove the excess water so clothes wouldn't come out dripping wet. the test lasted less than 10 seconds and the idea was aborted. LOL
Post# 1082989 , Reply# 14   7/29/2020 at 19:57 (1,356 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
Launderess
Regarding spin speed, there's something everybody that knows how to do laundry knows..
Not everything has to be about "energy efficiency".
1800 rpm obviously will extract more water, consequently you'll use less electricity (or gas) to dry the clothes.
HOWEVER
the clothes will last much less because of the stress caused by the higher G
So... the key is balance energy efficiency with "results".
I could make a washer that uses almost no water (just a 10 second spray on the clothes), no hot water at all, agitates for only 2 minutes on the longest wash cycle, rinse with a 3 second spray and spins at 20.000 RPM. it would be probably the very best washer in the world in terms of energy efficiency and water consumption. But.... What about performance? I would see a riot in front of our factory and protesters creating a group called GWM (good washers matter)
Post# 1082990 , Reply# 15   7/29/2020 at 19:59 (1,356 days old) by chetlaham (United States)
Why not? I would doubt any of is proprietary or trade secret.
Post# 1082993 , Reply# 16   7/29/2020 at 20:03 (1,356 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
@R11
No, can't be done I'm afraid.
Even vintage bolt down Bendix washers of old with their 300 rpm spin speed needed to be bolted down as directed.
There isn't a free lunch with H-Axis washing machines; forces generated during tumbling or spinning must be addressed somehow. Either by suspension system, or bolting into several feet of concrete or other substantial surface.
H-Axis washers are designed to send forced down to floor where they will dissipate throughout structure. Bolt down washers do more of this but units with suspension systems do as well.
In commercial use washer/extractors above a certain weight capacity most always have robust suspension systems nowadays. It is seen as preferable to sending all that forces down into the building which could cause all sorts of problems. Not saying would shake building apart, but under certain conditions those vibrations would be felt far and wide in building.
One reason early spin drier washers by Easy,GE and others weren't popular was because units tended to go walk about during spinning. Easy even sold little rubber casters to slip under washer's legs in aid of preventing this from happening. Many housewives weren't convinced and stuck with wringer washers. They may not have excelled at extracting water, but neither did they zoom around kitchen or laundry room either.
Post# 1083061 , Reply# 17   7/30/2020 at 07:05 (1,356 days old) by chetlaham (United States)
Anyway, can anyone tell me more about the Niagara? How many rinses does it do? PSC motor? I like the timer's labeling/setup.
Post# 1083141 , Reply# 18   7/30/2020 at 18:40 (1,355 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
Three rinses, standard (NOT ALUMINUM motor), belt drive electric Askoll pump, double solenoid fill valve (one of all fills and other for fabric softener), electromechanical timer, no electronics at all as per consumer requests, body 100% PP, SS and PP drum, water level intentionally high (1/3 of the drum) and, as expected for any HATL washer, the capacity is impressive for the size of the washer.
Extremely simple design.
More simple than that, impossible.
Post# 1083142 , Reply# 19   7/30/2020 at 18:43 (1,355 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
Chetlaham
Call me on Whatsapp +1 (661)2386684 and I can show it in the lab.
Post# 1083163 , Reply# 20   7/30/2020 at 20:56 (1,355 days old) by chetlaham (United States)
Thanks
Can you Email me?
Post# 1083165 , Reply# 21   7/30/2020 at 21:01 (1,355 days old) by chetlaham (United States)
I'd ditch the belt driven pump and go for a Hanning pump but thats just me. Everything else I like.
Post# 1083194 , Reply# 22   7/31/2020 at 05:10 (1,355 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
Oooops. i missed a comma there....
Belt drive (the washer is belt driven) COMMA electric pump
Post# 1083195 , Reply# 23   7/31/2020 at 05:16 (1,355 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
Also... more simple than that IS possible (and it's comming soon)
Same washer, 20 minute shut off timer, manual fill, separate on-off switch for pump. babysit the washer to fill, then come back to babysit the drainage and refill for rinse, maximum capacity 15% reduced, motor power reduced. Made after many "off-grid" customers begged me to create a solution under 300 Watts (for solar panels)
Post# 1083196 , Reply# 24   7/31/2020 at 05:18 (1,355 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
and for those missing an old school washer....
very soon we'll have a ROUND washer with an agitator somewhat similar to a Maytag Wringer (without the wringer)
AAAAAAAND EXTREMELY AFFORDABLE. (I mean REALLY inexpensive at the full meaning of the word "inexpensive"). Designed thinking of helping fixed income customers that struggle saving quarters for the laundromat.
Post# 1083201 , Reply# 25   7/31/2020 at 06:47 (1,355 days old) by PinkPower4 (USA)
@thomasortega / Niagara and New Products
I am looking forward to seeing these new products! Please post updates and videos when these products become available. How exciting, a manufacturer that FINALLY gets it. Good washers do matter and in the end save energy, water, time, our environment, and resources.
Thanks!
Post# 1083202 , Reply# 26   7/31/2020 at 06:48 (1,355 days old) by Rolls_rapide (.)
"Same washer, 20 minute shut off timer, manual fill, separate on-off switch for pump. babysit the washer to fill, then come back to babysit the drainage and refill for rinse, maximum capacity 15% reduced, motor power reduced. Made after many "off-grid" customers begged me to create a solution under 300 Watts (for solar panels."
It's funny (odd, peculiar) how the modern fully automatic washing machine has become an absolute liability, in terms of lacklustre performance, hellishly long cycles, and rubbish electronics.
With the user-controlled semi-automatics, we seem to have stepped back in time, to the era of the English Electric Liberator Tumble Wash, the Parnall Spinwasher, and dare I say, the twintub.
Civilisation must be crumbling.
Post# 1083221 , Reply# 27   7/31/2020 at 09:13 (1,354 days old) by Adam-aussie-vac (Canberra ACT)
The laundromat I’m going to tomorrow
May have two American Motex extractors, Not sure if they are employees only, If they are not, hopefully they’ve retrofitted them to more modern Safety standards, I’ll try to get some pictures tomorrow
Post# 1083223 , Reply# 28   7/31/2020 at 09:21 (1,354 days old) by chetlaham (United States)
That makes sense. BTW, in the pics posted on the Niagra website I think I see what looks like blue, red and yellow wires going to the motor. I like the choice of colors! Whirlpool I think uses red and yellow for their PSC motors- so I see what you did there! ;)
You switch both live and neutral with the power button? Mallory timer? What the yellow plastic plug thing for on the side of the tub?
I'm starting to fall in love with this design.
I will probably by one in a few months.
Honestly whatever you make without electronics I will appreciate.
Post# 1083225 , Reply# 29   7/31/2020 at 09:23 (1,354 days old) by chetlaham (United States)
PSC motor washer
A while back I drew this up for a washer without electronics:
Post# 1083226 , Reply# 30   7/31/2020 at 09:28 (1,354 days old) by chetlaham (United States)
Longing
I longing for a front load washer without electronics as well. Though spin will have to be limited because of that. But I'm willing to buy it. I don't like how modern Queens have an electric interface and an electronic motor control board.
Personally I'd like to see a motor with 2-4 poles for spin and 16-18 poles for tumble. Timer controlled, two chunky capacitors where the motor control sits. A pressure switch that once satisfied kicks off the water and turns on a heater.
Post# 1083241 , Reply# 31   7/31/2020 at 11:29 (1,354 days old) by jaums (Silver Spring, MD 20906 USA)
IOMH and dBT™ Quiet Control?
IOMH: In over my head, but seems we are going through a valid development phase, although in slow motion (more than a century and counting). More and more automation to excessive, then back up a bit to the then-recognizable sweet spot. Of course one person's sweet spot is wanting more automation which is excessive to the next person, so option buttons to adjust the automation.
My sweet spot would be to have lots of automation choices with options and full knowledge of what each choice actually does because most of my loads are mixed. I never have enough towels to warrant a separate load of towels.
dBT™ Quiet Control: The GE (Haire) name for their "new" quiet spin. Anyone know what it does; does it do anything unique? Or just their algorithm for multiple attempts?
CLICK HERE TO GO TO jaums's LINK
Post# 1083314 , Reply# 32   7/31/2020 at 19:18 (1,354 days old) by Adam-aussie-vac (Canberra ACT)
Here’s the laundromat with bock hydro extractors
Post# 1083368 , Reply# 33   8/1/2020 at 05:27 (1,354 days old) by ozzie908 (Lincoln UK)
@Adam aussievac
ozzie908's profile picture
On that Bock extractor does the lever on the front operate a lid lock so it can't spin while open?
We used to have such spin dryers in our launderettes they saved quite a while in the dryer, I have a number of separate spin dryers all capable of reaching speeds up to 3.100 rpms some items come out ironing ready and yes you do need to use an iron as they crease somewhat, But as I enjoy ironing its not an issue :)
Austin
Post# 1083378 , Reply# 34   8/1/2020 at 07:12 (1,354 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
One routinely spin dries linens of all sorts that have been hand washed, and will be ironed afterwards. To avoid heavy creasing trick is short extraction time. Far better to have things a bit moist and then hang to dry further as opposed to extracting to death, then having deep set creases.
One thing H-axis washing machines have over spin dryers is use of short periods of spinning, stopping, fluff wash, start spinning again, repeat......
While often frustrating to anyone waiting for cycle to finish, there is a method to madness. Those short pauses with fluffing between spinning redistributes loads for better and even extraction, and helps prevent deep creasing.
Back in days when there were only separate washers and extractors you'd have workers who felt if some spinning was good, more time is better. They would leave things in extractor so long what emerged was a solid mass of laundry heavily creased. Once other workers go through "shaking out" wash, and or it was put into a tumbler to break things up and fluff, things were evaluated before reaching or at finishing area. Ir the hand ironers or those doing things by machine said it was hopeless (as in they wouldn't be able to remove creases by ironing), everything had to go back to washing machines for several rinses to re-hydrate. This hopefully relaxed fabric removing deep creases. Then whole extraction process had to be done again.
As for Bock extractors, always thought would be nice to find one. Then read specs; they don't hold any more than domestic spin dryers (10 pounds). But you do get a larger basket so doing big items like blankets or even quilts isn't an issue. Also the larger tub means less creasing as opposed to domestic units.
Post# 1083381 , Reply# 35   8/1/2020 at 07:42 (1,354 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)
foraloysius's profile picture
IIRC the AEG Turnamat's spinner would spin for three minutes. Some separate spin dryers also advised a 3 minute spin. That time is long enough to get most of the water out, longer is not going to get more water out. And 3 minutes don't cause the worst creases like when the laundry is spun longer.
Post# 1083508 , Reply# 36   8/1/2020 at 23:56 (1,353 days old) by Adam-aussie-vac (Canberra ACT)
I found a bock extractor
I just hope the borders don’t close so I can get it
This post was last edited 08/02/2020 at 03:14
Post# 1083510 , Reply# 37   8/1/2020 at 23:57 (1,353 days old) by Adam-aussie-vac (Canberra ACT)
Ozzie
I think so, I honestly don’t know as I didn’t ask
Post# 1083553 , Reply# 38   8/2/2020 at 07:14 (1,353 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)
jamiel's profile picture
Our local laundromat had an extractor--I used it a couple years ago, actually...didn't realize they were so scarce. The laundromat had a suspicious fire about 18 months ago--they didn't touch the building for about a year (everyone's dry cleaning was hanging in that area---it was a smoky mess, of course). They've just now cleaned it out.
Post# 1084553 , Reply# 39   8/10/2020 at 03:47 (1,345 days old) by chetlaham (United States)
Reply #23
Regarding the Niagra:
How often does the tub reverse direction? Does it tumble as it fills? Does the timer stop during fills or keeps running? Does the user have to manually move the tub to get to the door or does the machine do that automatically?
Post# 1084555 , Reply# 40   8/10/2020 at 05:53 (1,345 days old) by Adam-aussie-vac (Canberra ACT)
Jamiel
Here’s a picture of the extractor I’m getting, The handle on the right of the lid Locks The lid closed, releases the brake and starts the motor, Although I think the switch is possibly stuck in the on position, I’ll look at it in more detail when it arrives
Post# 1084676 , Reply# 41   8/11/2020 at 03:02 (1,344 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
A few minutes ago I replied an email froma customer asking similar questions about the Niagara.
Just in case, this weekend I'll make a video in the lab to post here. It will be VERY splashy, washing with the lid open.
Post# 1084678 , Reply# 42   8/11/2020 at 03:08 (1,344 days old) by chetlaham (United States)
Video
That would be epic!
If these don't have a single semi-conductor in them in buying.
Lets just say I have handwash items that can not be spun through my Speed Queen ;)
Post# 1084680 , Reply# 43   8/11/2020 at 03:19 (1,344 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
Absolutely NOTHING electronic.
The most "complex" thing is an electromechanical timer similar to a vintage washer.
Even the clicking noises sound like a vintage washer.
Pressure switch also isn't electronic. a good and reliabe ANALOGIC pressure switch.
If somebody wants to adjust the water level (which is not necessary at all because I intentionally made the water level already ABSURDLY high to make D.O.E. hate me forever) One just needs to remove the top and adjust the pressure switch using a philips screwdriver. (be aware it's a PITA to do that)
as I mentioned before... I was made to be SIMPLE and RELIABLE.
Post# 1084681 , Reply# 44   8/11/2020 at 03:24 (1,344 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
I don't want to show off but.... The cleaning performance is actually BETTER than in a Speed Queen.
Post# 1084689 , Reply# 45   8/11/2020 at 05:07 (1,344 days old) by chetlaham (United States)
I like the sound of that! :)
Its ok to brag, your earned the rights to do so.
I like everything I'm seeing hearing about the Niagra washer.
Post# 1084690 , Reply# 46   8/11/2020 at 05:15 (1,344 days old) by chetlaham (United States)
Would pics of the timer or tech sheet be to much? I already like the choice of wire colors your using.
Well thought out machine. You could make a larger Staber version for customers who want a full size yet economical no BS washer but I doubt it would sell as well.
Honestly I wish you could make full size washers considering how well you are doing with portables. You have a gift, and I like it! :)
Post# 1084691 , Reply# 47   8/11/2020 at 05:17 (1,344 days old) by chetlaham (United States)
Staber
For those wondering:
www.staber.com/product/81...
But its ridiculously priced. And has electronics. Yuck.
Post# 1084714 , Reply# 48   8/11/2020 at 08:27 (1,343 days old) by Adam-aussie-vac (Canberra ACT)
Thomas
Can you define PITA? I know it’s not the kind of bread by the same name
Post# 1084716 , Reply# 49   8/11/2020 at 08:44 (1,343 days old) by ozzie908 (Lincoln UK)
PITA
= Pain In The Ass....
Post# 1084717 , Reply# 50   8/11/2020 at 08:52 (1,343 days old) by Adam-aussie-vac (Canberra ACT)
Oh,
Thanks Ozzie
Post# 1084746 , Reply# 51   8/11/2020 at 16:11 (1,343 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
Regarding the full size, not portable HATL washer.
1) It will be way bigger
2) There will be a version that also dries
3) For the version that dries, there will be a GAS version.
4) All of them have internal heater (gas version will have a GAS heater)
5)It's impossible to make it electronics-free, but I intentionally kept electronics to a minimal, only what was impossible to avoid.
6) The electric version will be vented and there will be another verson that's condensing.
7) Stainless steel in and out.
8) I'm trying to make it a self contained suds saver. Not sure if the cost will allow that.
9) Intentionally designed to look like a vintage washer the concept is all around 1940's and 1950's "industrial" look.
10) Kevin's (Revvinkevin) Coin op westinghouses were an excellent source of inspiration for the cosmetic design.
11) It will have some bells and whistles and "easter eggs" that people here on AWO will faint when they see. (No, it won't play "how dry I am" because that's not "original")
12) Yes, it will "play" something. Inspired on one of my favorite Hanna Barbera cartoons but not exactly like that due to copyright and that will be electronic... adding a xylophone would be TMI nowadays.
13) 10-year full warranty (parts and labor) as standard.
14) Whirlpool will probably want to send somebody to murder me.
15) 100% MADE IN U.S.A.
16) It will be freaking expensive but we don't care. You're going to be getting what you paid for.
Post# 1084763 , Reply# 52   8/11/2020 at 19:46 (1,343 days old) by Adam-aussie-vac (Canberra ACT)
I can’t wait to see pictures of this
Well that I’m a little bit confused are you talking about a top loading washer and dryer?
Post# 1084764 , Reply# 53   8/11/2020 at 19:56 (1,343 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
Reply # 51
combo52's profile picture
Sounds great Thomas, Only problem I see is getting someone to pay $25,000-$30,000 for a washer-dryer.
And if you can't get production above 10,000-40,000 units a year it may actually cost MUCH more.
John L.
Post# 1084772 , Reply# 54   8/11/2020 at 23:10 (1,343 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
John, it won't cost that much.
It will be around $4k for the washer-dryer combo gas.
Post# 1084784 , Reply# 55   8/12/2020 at 01:59 (1,343 days old) by chetlaham (United States)
Combo
Why so expensive? Why not just put a blower on the drum and and a heater box above it?
Post# 1084785 , Reply# 56   8/12/2020 at 02:56 (1,343 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
I actually understand what John tried to say. Unfortunately some costs here in the USA are really outrageous. Add to this the "corporation" thing (having to make shareholders happy). The result is what we've seen happening for decades: quality being replaced by "profit", so meticulously calculated that we end up seeing stupid things like washers that last 50% less because or a simple bearing that would have costed 25 cents more. Plus planned obsolescence, etc, etc, etc.
Add to that the culture of making people believe something is really absurdly expensive because of a silly feature, like "Look, this model costs 3x more but it has an interior light and the power plug has out logo on it.
For a small family company(now not so small thanks to COVID), we dont need to make shareholders happy, so we have a bit more freedom.
Luckily at this point, the CEO really trusts me and gives me the green light to use all my knowledge and expertise. I was also able to educate him about many things, for example bells and whistles may make some younger customers happy and the market is full of models with tons of bells and whistles. But the market has a giant deficit of "No-nonsense" models focused on performance and durability.
It's a shame that the Golden era of the American engineering was completely forgotten by AMERICAN corporations and an immigrant is the only one trying to bring it back.
Our company survived and thrived with cheaper models. If you pay attention to our product timeline, there was a huge improvement starting in 2016, when I joined the company. We'll never stop.making those low cost products because they're part of our DNA. We may not add some features to keep them affordable, but we will never "save 5 cents on a part", sacrificing quality to protect profit.
And now, we're slowly starting to add more products and parallel to that develop medium and high end models.
Some products I am authorized to openly talk about because they're going to be released very soon are:
1)round washer inspired on a maytag wringer (mentioned above). It won't be a washer that people here will say "Wow, it's fantastic, it's wonderful, it's the best thing since sliced bread", but it will do a decent job and will last average 10-12 years under normal household use. And costing under $100. Again, you get what you paid for, but at least we tried to do our best to make it reliable. Our competitor is those Chinese craps sold on eBay that comes with a 30-day warranty and a 6-month expected life.
2) We're bringing back the "Scirocco" washer from the 1980s. Now much improved, more reliable, more functional, automatic and it will have the drying.
Small capacity, the drying isn't the very best thing in the world, but it works. If you have a spin dryer, that washer can be a lifesaver if you live in an RV.
Competitor is an expensive front load all in one unit. Of course it will be better than our little scirocco, but its not portable, its not super compact, and its not affordable, specially for people that live on fixed income and struggle using laundromats.
3) The niagara spin off. Everything in it was calculated considering the worst case scenario of a family living off-grid. It MUST work using a crappy walmart amazon portable solar panel because those customers can't afford a better solar system. It has to be functional, it has to be inexpensive, but it can not leave quality behind. Our competitor, in this case is a washboard in an RV bathtub.
We will definitely make A LOT of noise on the next few months.
Post# 1084791 , Reply# 57   8/12/2020 at 06:25 (1,343 days old) by chetlaham (United States)
I'm so proud of you! :) And grateful that you exist.
I'd really try and make a low cost combo. I'm figuring that if the machine does not spin, you can easily add a blower and heater for just a bit more. But thats me just imagining.
I have to say, my mind is still swimming from the Niagra.
If you could start producing a no none sense DW and stove I think this could make the company compete with Whirlpool.
You will never meet another no none sense person like me I think.
Post# 1084795 , Reply# 58   8/12/2020 at 07:09 (1,343 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
A New Gas Combo, Reply # 51
I may be off in the retail price somewhat, but it will still be north of $10,000 easily if it does even 3/4 of the things you list in reply # 51.
We have ranges in this country that cost $10,000 too over $20,000, many high end refs cost over $10,000.
I am glad you are here Thomas the world needs big thinkers and dreamers, I dream of designs and machines I would like to see as well, I do believe full sized combination washer-dryers will make a comeback and do fairly well. But it will take a large company to do it and even then it will cost over $4000.
When you look at the several people that thought they would build an original automobile over the last 50 years no one has ever succeeded in doing much more than blowing through millions of dollars.
John L.
Post# 1084897 , Reply# 59   8/13/2020 at 00:50 (1,342 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)
...Not when you have 30 somethign products subsidizing the costs...
And after they "catch up", it's a different story.
Today my husband and I spent 500+ dollars ona food processor, known as the "badass" creme de la creme of household food processors.
We had no other alternative, but I'm sure it costed no more than $20 for the manufacturer.
Once we break this "we need to have absurd profit so our products will be considered superior just because they're expensive and very few people can afford them", things get much easier.
Years ago, would you believe a company would make a HATL washer that doesn't cost a fortune? Well, it's on the market since last year.
Post# 1084912 , Reply# 60   8/13/2020 at 05:31 (1,342 days old) by chetlaham (United States)
Reply 58
I'm not buying it. You've got China making products pennies on the dollar in part from over simplified minimalist design.
I can't see why someone can't stick a heater and a blower on cheap FL design. If you ditch the suspension and counterweights (no spin) that can offset the cost. Less efficient yes but you've got a low priced combo that will create a market.
Post# 1084923 , Reply# 61   8/13/2020 at 07:01 (1,342 days old) by GELaundry4ever (Nacogdoches, TX, USA)
also
it should be able to do everything, including the entire wash, rinse, and dry all with extractions in between them and a powerful spray rinse to boot.
