Thread Number: 83998
Cold Special cycle On speed queen laundromat washing machines |
Post# 1083386 , Reply# 1   8/1/2020 at 09:05 (1,361 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1083506 , Reply# 2   8/1/2020 at 23:52 (1,360 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
I’ll ask them to use hot next time |
Post# 1083582 , Reply# 3   8/2/2020 at 12:32 (1,360 days old) by appnut (TX)   |   | |
Post# 1083583 , Reply# 4   8/2/2020 at 12:34 (1,360 days old) by appnut (TX)   |   | |
Post# 1090468 , Reply# 5   9/24/2020 at 08:11 (1,307 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
It was the same price |
Post# 1090492 , Reply# 6   9/24/2020 at 09:53 (1,307 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
when i was on vaction last year 3 days disney 4 days sarasota while in sarasota i go to the hotel laundromat laundry in speed queen front lauder had to use 2 washers 1 for colors the other for white white i set the washer to warm the color load cold they had put a panel not to use hot water for the washer i will never understand why
Post# 1090493 , Reply# 7   9/24/2020 at 09:54 (1,307 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
To wash big rugs and the like, charges .25 to .50 more per load for hot washes. In reality their warm wash is maybe body temp, maybe a little cooler. Hot wash is more what I would call a warm.
Combined with a quick wash cycle, you can pay another .25 for a heavy wash. The results were minimal at best. |
Post# 1090499 , Reply# 8   9/24/2020 at 10:41 (1,307 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Went to laundromat yesterday only because had large coverlets that simply couldn't be done in any washers at home.
Started going off laundromats long before covid-19 hit, and now am even more squeamish, but what else could one do? Am here to tell you our local has SQ front loaders, and no; you will never get a "hot" wash. First cycle is a quick pre-wash in cold water. Then comes tap hot water which even if 140F (which I doubt) would be quickly cooled by both interior surfaces of washer and that laundry pre-washed in cold water. |
Post# 1090513 , Reply# 9   9/24/2020 at 13:03 (1,307 days old) by DADoES (TX, U.S. of A.)   |   | |
There's a lot of heat loss without an onboard heater. My AquaSmart ATC is 50°C/122°F for WARM input. Warm+ is 56°C/133°F and Hot is 62°C/144°F. Most cycles run the target temp only for the Eco Active fill (some also for the HE top-off), tap cold for deep fill top-off if selected or coded into the cycle. *However*, a few deep fill cycles such as Sheets (which can also do Warm+ and Hot) and Bulky run the target temp for the entire fill. I've been using Bulky-Blanket for bedding, which is hard-coded for Warm. The resultant temp is nicely warm, surely not 122°F. |
