Thread Number: 84001
/ Tag: Vintage Dryers
1978 Whirlpool 220 portable dryer wiring |
Post# 1083436 , Reply# 1   8/1/2020 at 15:19 (973 days old) by chetlaham ![]() |
Post# 1083439 , Reply# 2   8/1/2020 at 15:25 (973 days old) by chetlaham ![]() |
I ask because the model number of your generator brings up a manual showing 120/240 as standard- meaning you can get both 120 and 240 out of the generator at the same time page 40 (6-6)
www.cleggind.com/postal_tech/pdfs... |
Post# 1083534 , Reply# 3   8/2/2020 at 05:28 (972 days old) by Vintagemh (Saskatoon )   |   | |
oh let me find out, thank you! |
Post# 1083579 , Reply# 4   8/2/2020 at 12:06 (972 days old) by chetlaham ![]() |
Post# 1083597 , Reply# 5   8/2/2020 at 14:37 (972 days old) by Vintagemh (Saskatoon )   |   | |
Even if the generator can service the needs of the dryer and the rest of the coach how could I wire a switch to allow it to switch between 110 and 220? |
Post# 1083622 , Reply# 6   8/2/2020 at 17:44 (972 days old) by chetlaham ![]() |
Do you have a schematic or tech sheet to this combo?
Normally you would jump L2 to the neutral and only use the timed dry or low heat setting. You will get 1/4 of the normal heating power from the dryer. (see pic of a typical dryer wiring diagram) However, with a combo, I've seen the washer motor L1-N, while the dryer motor is L2-N. A bit more complicated than a jumper. You could in theory wire the thing to a 15 amp 120 volt circuit and have a switch where either the washer works or the dryer works but not both. |
Post# 1083623 , Reply# 7   8/2/2020 at 17:46 (972 days old) by chetlaham ![]() |
