Thread Number: 84018
/ Tag: Modern Dishwashers
Dishwasher Issue |
Post# 1083596 , Reply# 1   8/2/2020 at 14:34 (1,360 days old) by DADoES (TX, U.S. of A.)   |   | |
There are three boards. Main control board 154320603 NLA. Display board 154227901 NLA. Keypad 154322801 available. Maybe the keypad is flaky, not the main board? Google search the main board number, a few sources claim to have it (may or may not be accurate, contact them to confirm). There are also some used, new, open-box on eBay. |
Post# 1083607 , Reply# 2   8/2/2020 at 15:19 (1,360 days old) by steved (Guilderland, New York)   |   | |
and I read they were notorious for water getting into the keypad and causing all sorts of craziness. I replaced the keypad once for reasons I can't remember, and it solved the issue. |
Post# 1089788 , Reply# 4   9/18/2020 at 07:30 (1,313 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You have come close to setting a record for life out of one of these FD DWs, unless you just want to throw money and your time into this one I would shop for a new DW.
These DWs also have a host of other problems waiting for you, The main wash pump motors are very short lived, and then you have the likely hood of broken heater mounting nuts which will cause leak underneath and shorted heater, bad drain pump, bad inlet valve, and just general things like rusted racks.
If this DW has had normal once a day use it is probably close to the end of its useful life, if it has had much lighter use you may be able to push it along for some years. It is a shame they used such short lived components because the performance was pretty good, the worst thing about these DWs was the messy filter in the bottom.
Post# 1089792 , Reply# 5   9/18/2020 at 09:06 (1,313 days old) by kb0nes (Burnsville, MN)   |   | |
