Thread Number: 84034
/ Tag: Modern Dryers
LG TROMM DLG2526W Gas dryer. |
Post# 1083757   8/3/2020 at 12:27 (1,355 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
I pulled this off of marketplace yesterday. I ordered the Natural Gas orifice because this one was propane. Also I found this video of a different model with I think it is a faulty flame sensor or igniter or gas valve coil or maybe even the CCU (machine controller). What is the percent chance of this happening on any given cycle to ME? or will I hear a pop on the CCU indicating a malfunction. On the Video after the Burner is shut off the igniter seems to be glowing very faintly so the flame sensor is probably defective or the controller is bad. I am a little concerned of this happening to me but the main problem is electric is too expensive to run. Whenever I bring ANY electric Dryer into the house the electric bill goes up $20-$50 and my Dad is NOT fond of that. so Gas is generally my only option unless it is rare like my Fisher&Paykel DEGX1. Have you encountered this problem on any Given Dryer before. I know that is isn't an LG Specific failure but ANY BRAND can have this problem. Has anyone encountered it before? Let me know. Say Encountered this failure on a (Brand) Gas Dryer.
CLICK HERE TO GO TO MaytagNeptune's LINK |
Post# 1083824 , Reply# 2   8/4/2020 at 07:42 (1,354 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I have seen LG dryers do this little trick of just dumping gas without igniting it.
Fortunately it is not as dangerous as it sounds because the gas is so quickly dulouted that it will not combust, However if the dryer is not properly vented outside it could get just a little dangerous.
The BIG question is why even brother with an LG gas dryer for your home ?, we build the worlds best gas dryers in this country and used ones are a dime a dozen.
These full sized LG & SS dryers are just a cheap copy of WPs 27" dryers that WP introduced in 1988.
Hi Richard, I do commend you for tackling some of this newer junk, but from my experience as an appliance professional the last thing I want to see when I come home is a broken appliance, I see this stuff all day long.
Post# 1083842 , Reply# 3   8/4/2020 at 10:02 (1,354 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1083871 , Reply# 4   8/4/2020 at 14:04 (1,354 days old) by Maytag85 (Sean A806)   |   | |
Post# 1087725 , Reply# 5   9/2/2020 at 21:51 (1,325 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
I feel like I didn't put something back in right. I am going to get an LG DLE5977W and Use the Harness and burner from this one to convert it and then get the board for DLG5988W and convert it to gas. I honestly like Electric Better. It is leaking air and I am concerned about the gas valve problem and it leaking gas into the air and not exhausting it. When I get the DLE5977W and if it works and Heats fine then I am going to leave it how it is and part out this one. I am not going to have Natural gas or Carbon Monoxide leaking into the air. I enjoy babysitting the Washer and Dryer to watch them go through the cycle but I digress. I just think leaking Exhaust is a bad thing. I tried everything to fix it. from placing the dryer on the duct and wrapping it with foil tape. My dad put a screw through the duct and it crushed the dryer Duct so now it is permanently deformed. If this DLE5977W doesn't leak then I am tossing this one and using the DLE5977W. My Fisher&Paykel DEGX1 and Maytag MDG5500AWW and my Aunt's DLE2532W all don't leak.
Post# 1087756 , Reply# 6   9/3/2020 at 06:55 (1,324 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Kelly, the only place a dryer can leak air is from the blower on, this is 20" of vent pipe and very easy to seal, how can the pipe be crushed by a screw ? just straighten it out, aluminum tape is practically water tight there should be no measurable leaking of air.
How do you know this dryer is leaking ?, What reading are you getting on your CM meter ?
This dryer only produces a 1/10 the of the carbon monoxide your gas kitchen range does, how are you controlling that ?
Post# 1087789 , Reply# 7   9/3/2020 at 11:49 (1,324 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1087792 , Reply# 8   9/3/2020 at 12:33 (1,324 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1087797 , Reply# 9   9/3/2020 at 13:32 (1,324 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1087820 , Reply# 10   9/3/2020 at 17:46 (1,324 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1087826 , Reply# 11   9/3/2020 at 18:23 (1,324 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1087831 , Reply# 12   9/3/2020 at 18:42 (1,324 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1087837 , Reply# 13   9/3/2020 at 18:52 (1,324 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Virtually every WP clothes dryer ever built including now has a steel blower housing.
WP has worked hard to prevent dryer fires, that't why you don't see plastic door liners like Maytag and others used for years
Has anyone noticed that WP quit using rubber-vinyl type door seals on their dryers and instead have gone to a woven fiber gasket like self-cleaning ovens use to reduce fire risk.
Post# 1087875 , Reply# 14   9/3/2020 at 22:38 (1,324 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1087877 , Reply# 15   9/3/2020 at 23:02 (1,324 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1087923 , Reply# 16   9/4/2020 at 09:39 (1,323 days old) by littlegreeny (Milwaukee, WI)   |   | |
But I did watch a half dozen LG dryer repair videos this morning and they all had metal blower housings. It looks like some Electrolux dryers have plastic housings and surprisingly, a fairly brand new Speed Queen dryer had a plastic blower housing.
Thanks for the education. This is now going to be something I look for in a new dryer. No Speed Queen for me now. That's disappointing since I'd like to support a local company. |
Post# 1087934 , Reply# 17   9/4/2020 at 12:57 (1,323 days old) by appnut (TX)   |   | |
