Thread Number: 84063
Maytag bravos xl fill issue |
Post# 1084193 , Reply# 1   8/7/2020 at 07:02 (1,357 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Have you disconnected both inlet hoses from the washer and pointed them into the washer and turned them on one at a time to see if the house pressure and the shut-off valves are capable of very good water flow ?
This is pretty much a problem with the house plumbing or the inlet valve in the washer.
Post# 1084195 , Reply# 2   8/7/2020 at 07:36 (1,357 days old) by Gmarquez (Bakersfield)   |   | |
Yep we checked the hoses and there’s really strong flow out of both the hot and cold valves. It’s just weird it’s still doing this after having the inlet valve replaced already. |
Post# 1084196 , Reply# 3   8/7/2020 at 07:39 (1,357 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1084206 , Reply# 4   8/7/2020 at 08:47 (1,357 days old) by Yogitunes (New Jersey)   |   | |
Post# 1084212 , Reply# 6   8/7/2020 at 09:57 (1,357 days old) by eronie (Flushing Michigan)   |   | |
The restrictor is behind the screen. |
Post# 1084217 , Reply# 7   8/7/2020 at 10:40 (1,357 days old) by Yogitunes (New Jersey)   |   | |
