Thread Number: 84118  /  Tag: Vintage Automatic Washers
POD 8/11/2020
scroll >>> for more items
Post# 1084740   8/11/2020 at 14:17 (963 days old) by rinso (Meridian Idaho)
rinso's profile picture
The old GE filter flow washers were well-made and reliable. They did have awesome turnover if not overloaded and did clean clothes well, if a bit harshly. It didn't matter back then, but those machines were really water hogs. A big outer tub also filled with water. IIRC, they basically used the same outer tub as with their previous, solid inner tub designs.
Post# 1084773 , Reply# 1   8/11/2020 at 23:17 (963 days old) by Spinmon (st. charles mo )
Really? That seems crazy. I'm familiar with KMs BD & DD, & '63 Frigidaire. No GE machines. I don't think I missed much. Wash on.
Post# 1084780 , Reply# 2   8/12/2020 at 00:15 (963 days old) by PeterH770 (Marietta, GA)
Truth
peterh770's profile picture
Unlike other brands, the outer tub of the GE was bolted to the cabinet. In fact, the top of the washer doubled as the top of the outer tub. So instead of the inner and outer tub riding on the suspension, only the inner tub did. This left a lot of room on the side and bottom for lots and lots of extra water, and why they had that funky, huge tub seal between the outer tub and the transmission to accommodate the movement and balancing of the inner tub during spin.
Post# 1084786 , Reply# 3   8/12/2020 at 05:27 (962 days old) by Paulwash (Niagara Falls New York)
paulwash's profile picture
I disagree .. with the water hog misconception I filled my large capacity Ge filter flo or hotpoint rim flo to the top highest level then I drained it into a 90’s direct drive filling it only to the medium level totally drained out .. try it you’ll see. Look at the older 60’s models washers with the constant OVERFLOW RINSING ALL YOUR FABRIC SOFTNER AWAY!! Those were the water wasters !!!
Post# 1084787 , Reply# 4   8/12/2020 at 05:42 (962 days old) by arbilab (Ft Worth TX (Ridglea))
arbilab's profile picture
I LIKE my fabric softener rinsed away.  B-u-u-a-a-h!
Post# 1084789 , Reply# 5   8/12/2020 at 06:06 (962 days old) by tolivac (greenville nc)
I don't use fabric softeners AT ALL!!!
Post# 1084800 , Reply# 6   8/12/2020 at 07:40 (962 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
GE FF Washers
combo52's profile picture
Reply #3, Hi Paul It is true the GE FF did not use that much more water than other extra large TL washers, BUT GEs big washers did not hold nearly as much clothing as the Super capacity DDs or the SC BD WP built machines.
John L.
