Thread Number: 84155
/ Tag: Modern Dishwashers
Frigidaire top rack only |
Post# 1085166   8/15/2020 at 13:43 (1,347 days old) by rpms (ontario canada)   |   | |
Just wondering if only the top arm sprays or do both arms still spray and the cycle is just a short cycle. I know the arms alternate on a normal cycle but does just the top arm spry?
The instructions don't really say what it does.Could you still put plates and silverware in the bottom and hope the water coming down cleans them? |
Post# 1085173 , Reply# 1   8/15/2020 at 14:22 (1,347 days old) by appnut (TX)   |   | |
I've never used a Frgidaire. But on my KitchenAid produce Kenmore Elite, it still uses the bottom spray arm some, largely to flush out the whole water distribution system and filter. Even when I do bottom rack only, it still sprays quite a bit on upper rack. With this knowledge, I began putting lightly soiled plates, salad plates, and mini plates in the bottom rack even when I do top rack only. And same with flatware. You will just need to experiment.
Post# 1085181 , Reply# 2   8/15/2020 at 16:32 (1,347 days old) by parunner58 (Davenport, FL)   |   | |
We had this Frigidaire Gallery DW and when I tried the top rack only you could hear it alternate between the lower and upper wash arms. We only kept it for about 5 years because the upper rack kept falling off the supports. I did not like the plastic tub. We replaced it with a Bosch 300 series and never looked back.
Post# 1085204 , Reply# 3   8/15/2020 at 17:11 (1,347 days old) by seedub (South Texas Hill Country)   |   | |
