Thread Number: 84302
Trying out a cheap front load washer controller |
Post# 1087054 , Reply# 1   8/29/2020 at 01:44 (1,330 days old) by richnz (New Zealand)   |   | |
How much did that beauty set you back? Good luck it getting it to work. Perhaps a video of it in action is called for? Rich |
Post# 1087057 , Reply# 2   8/29/2020 at 02:37 (1,330 days old) by gizmo (Victoria, Australia)   |   | |
I'm guessing "string excitation mode" would mean it is for series-wound motors. (normal brush-type motors.) The fields and armature are wired as a "string" in series motors, in parallel for shunt-wound motors. |
Post# 1087075 , Reply# 3   8/29/2020 at 07:31 (1,330 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
So no big loss, I’m probably thinking about putting it in a dead Asko machine |
Post# 1087215 , Reply# 5   8/29/2020 at 21:59 (1,329 days old) by Tomdawg (Des moines)   |   | |
Ohhh, I could go for one of these! Totally would make up my own wash cycle if I could... |
Post# 1087243 , Reply# 6   8/30/2020 at 06:31 (1,329 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
You the link, not sure if you can change the programs CLICK HERE TO GO TO Adam-aussie-vac's LINK |
Post# 1088423 , Reply# 8   9/8/2020 at 08:09 (1,319 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Post# 1088459 , Reply# 9   9/8/2020 at 12:12 (1,319 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
More info is needed on this! This is nearly exactly what I want! If I could find a way to program my Duet if the MCB goes bad, that would be incredible. |
Post# 1088504 , Reply# 10   9/8/2020 at 17:19 (1,319 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
I guess the only thing that you really need is just a brush motor on it, as well as to make sure the door lock uses a PTC heater, I have to go to the electronic store and buy a relay so that way the door lock would be disengaged from the door open button |
Post# 1092080 , Reply# 13   10/5/2020 at 14:27 (1,292 days old) by LowEfficiency (Iowa)   |   | |
