Thread Number: 84359
/ Tag: Vintage Dishwashers
Stainless Steel Panels |
Post# 1087499   9/1/2020 at 10:04 (1,325 days old) by kakidd (Texas)   |   | |
Is it possible to find stainless steel panels somewhere for a Kitchenaid KDS-17a? |
Post# 1087718 , Reply# 1   9/2/2020 at 21:13 (1,323 days old) by dnastrau (Lords Valley, PA)   |   | |
This might be a solution... Andrew S. CLICK HERE TO GO TO dnastrau's LINK |
Post# 1087736 , Reply# 2   9/3/2020 at 00:20 (1,323 days old) by RP2813 (Sannazay)   |   | |
This Thermador had custom panels to match cabinetry when I picked it up about a dozen years ago, but unfortunately, they didn't match my cabinetry so something had to be done. Trying to find a factory replacement panel was a total non-starter, so Nate and I went to Orchard Supply Hardware and found our solution with sheets of aluminum in a special manufacturer's display rack. We cut sections to fit both the door and access panels and pulled off the look of stainless steel for a fraction of what that material would have cost.
Post# 1087766 , Reply# 3   9/3/2020 at 09:16 (1,323 days old) by DADoES (TX, U.S. of A.)   |   | |
KA-17 panels aren't flat. The upper panel has the edges turned 90° to fit around the the door. The lower panel has same and a large bottom flange with tabs for the anchor screws. See the pic below and also reply #11 for the bottom panel.
Post# 1087961 , Reply# 4   9/4/2020 at 17:45 (1,321 days old) by RP2813 (Sannazay)   |   | |
