Thread Number: 84427
My Cylinda FTL56 |
Post# 1088136   9/6/2020 at 12:47 (1,326 days old) by AskoBoy (Sweden)   |   | |
I am obsessed with this washing machine as it may do a 60C wash in 50 min only if it it is a small load |
Post# 1088149 , Reply# 3   9/6/2020 at 14:20 (1,326 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hello Maximilian and a warm welcome to Automatic Washer , you will find a few Asko washers here in the archives, Ive had mine since 2001 under the Maytag Asko brand name because of the distributor rights here in the UK at the time...
These have worked tirelessly for 10 yrs and now in the vintage wash room where they perform on a regular basis, love the fact you can do a 95d n boil wash with 4 rinses and a 1600rpm spin in just an hour, total flexibility and so simple to operate ... I also have the Asko 1300 toploader and a 1200 white set that doesnt have the drop down washer door !! I worked at an Independent Electrical Store in Manchester mid 80`s and they where the first to have Asko products on display, have loved them since then!! |
Post# 1088397 , Reply# 5   9/8/2020 at 00:47 (1,324 days old) by FreshNclean (WA)   |   | |
How do the Swedish asko compare to the international asko ? |
Post# 1088567 , Reply# 6   9/9/2020 at 00:37 (1,323 days old) by askolover (South of Nash Vegas, TN)   |   | |
My Swedish made Asko was bought new in 1997, is on its third motor, second drain pump, and second drive belt. The timer has gone caput but I have one to replace it, just haven't had the time. It still washes but I have to advance it manually. It just keeps going and going. I'd take another one but I don't know how the Gorenje machines are holding up yet.... I don't have an Asko dryer...gas is cheaper for me so I have two American gas dryers. |
Post# 1088757 , Reply# 7   9/10/2020 at 08:45 (1,322 days old) by AskoBoy (Sweden)   |   | |
Let me ask what model is it? I really like the asko 12605 |
Post# 1088911 , Reply# 8   9/11/2020 at 04:25 (1,321 days old) by askolover (South of Nash Vegas, TN)   |   | |
Mine is the WM80 aka 8005. It was the only 120V model they sold in 1997, but it is a genuine "made in Sweden" machine complete with a heater. Inside it has a huge step-up transformer and all the parts inside are 240V. |
Post# 1088914 , Reply# 9   9/11/2020 at 04:41 (1,321 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1088922 , Reply# 10   9/11/2020 at 06:03 (1,321 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
These American Asko washers (8005) only had three wash temperatures; Hot-140F, Warm -50/50 tap hot and cold, finally Cold - tap cold water.
Machine had a 1450 watt heater so it could in theory heat tap water to hot (140F), but no option for boil washing. www.manualslib.com/manual... This Asko was rather a limited machine IMHO, but one they introduced to North American market that got around same issues Miele and Creda (who also introduced compact front loaders from Europe to market at same time), getting around 208v-240v electrical requirement. Over years have seen more than a few early Asko units pop up; but always backed away. Even back before purchased Miele had hard about Asko washers going through motors, belts, drain pumps, etc... My Miele OTOH is > 20 years old (knock wood) and still has original motor. Yes, had a new drain pump installed about ten years ago, and other bits like shocks and suspension system. |
Post# 1088974 , Reply# 11   9/11/2020 at 11:16 (1,321 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Thank you for the link! I love manuals, especially from machines that are out of the ordinary. And this Asko certainly is. I guess Asko wanted to put a machine on the American market with a control panel that was similar to an American toploader. I see the spin speed is also only 1000rpm, IIRC Asko's from that time spun at 1200rpm.
Earlier Asko (labeled Asea) were very sturdy built, especially the frame. But they had some weak spots, most of them were gone after 10 - 15 years. |
Post# 1089056 , Reply# 12   9/11/2020 at 20:50 (1,320 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
That quick start manual was only thing could find online for Asko 8005. Full owners manual likely would go into deeper details, especially about water temperatures.
I for one would be curious if 8005 could work as cold fill only, or would only do warm as 50/50 hot/cold tap water. As for spin speed maybe the reduction in rpms from 1200 to 1000 came as result in changing power requirements from 208v-208v 50hz to 120v at 60hz. Spin speed would actually be about 10% faster at 60hz over 50hz, but maybe Asko had reasons for limiting things to 1000 rpms instead. Think as "Cylinda" washers Asko units were great, but still had issues with longevity. They just didn't seem to have same build quality as Miele washers. |
Post# 1089098 , Reply# 13   9/12/2020 at 08:02 (1,320 days old) by askolover (South of Nash Vegas, TN)   |   | |
I think hot was actually closer to 150 because it will get hotter than my water heater that was set on 140. But it always does a good job. I was actually looking at Miele and AEG back then too. The Asko won because of the 120V model. This post was last edited 09/12/2020 at 09:12 |
Post# 1089104 , Reply# 14   9/12/2020 at 08:58 (1,320 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
According to the manual it heats up to max. 140F.
Post# 1146499 , Reply# 15   4/13/2022 at 19:19 (742 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Did they have a normal program? I know they rename it the everyday program. |
Post# 1146779 , Reply# 17   4/17/2022 at 12:30 (738 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
How do the cottons programs of heavy and light compare? What do you use the cottons heavy for? Can you use cold on the heavy cotton program if you want to wash sturdy colors? |
Post# 1146822 , Reply# 19   4/17/2022 at 20:36 (737 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Was fairly common for older European washing machines to have an "Easy Cares" cycle that allowed temps ranging from hot to boil wash territory.
My Miele W1070 will allow 200 degrees F for delicates, easy cares along with normal cottons/linens. What matters with synthetic fibers is more about drum rhythm, and cooling down wash before any spinning. This and limiting final spin to short durtion. Polyester and other man made fibers often profit from a good hot wash. Commercial laundries do such fabrics at 140F to 160F, but they cool down gradually and of course don't extract between changes of water. |
Post# 1146824 , Reply# 20   4/17/2022 at 20:42 (737 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Have you tried washing colors made of cotton or linen or a blend of the 2 on cottons 30 or cold? How did it turn out? |
Post# 1146841 , Reply# 21   4/18/2022 at 02:59 (737 days old) by rudin1969 (Italy)   |   | |
What matters with synthetic fibers is more about drum rhythm Why do you think many synthetic cycles use exactly the same drum rhythms as cotton cycles? |
Post# 1146842 , Reply# 22   4/18/2022 at 03:23 (737 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1146851 , Reply# 24   4/18/2022 at 08:30 (737 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
