Thread Number: 84678
/ Tag: Modern Dishwashers
new bosch dishwasher instalation us model canada |
Post# 1091149   9/29/2020 at 09:07 (1,297 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
hello to all aw members will 2020 bosch dishwashers like whirlpool kitchen aid maytag will require a power cord for canadien us made modeles? this part to be precise thank you for your answer even check online the installation manuel
CLICK HERE TO GO TO Pierreandreply4's LINK |
Post# 1091808 , Reply# 4   10/3/2020 at 10:00 (1,293 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Here is a website for plugs, sockets and voltages around the world.
www.worldstandards.eu/ele... As for the start of a new thread: Perhaps it's good to realize that not everyone has abilities and skills to use the internet like others. There are people with limitations and also some people who are blind. It's not to us to judge if posting gets out of hand. If you think something is going on, please report it to the webmaster instead of commenting in the thread. Robert can't keep an eye on everything on this website, so if something serious is going on he is happy to accept your help. For the rest I can only say that patience is still a virtue. Especially in the communication with others on the internet. You don't know who is behind it. Thanks for listening. Louis |
Post# 1091811 , Reply# 5   10/3/2020 at 10:10 (1,293 days old) by chachp (North Little Rock, AR)   |   | |
Post# 1091910 , Reply# 7   10/4/2020 at 11:30 (1,292 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
this is the powercord for the bosch model she purchuse in the pdf file i have read online its option 2 option 1 is a junctionbox but i think it would be more safe security reason to go with the powercord in the sink cabinet that way if leaving the house the dishwasher can be unplug and replug when back exemple vacation or a family event out of the house
Post# 1091915 , Reply# 8   10/4/2020 at 12:50 (1,292 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1091917 , Reply# 9   10/4/2020 at 13:22 (1,292 days old) by DADoES (TX, U.S. of A.)   |   | |
Salt is involved only if the dishwasher has a built-in water softener, which functions the same as a whole-house water softener machine but on a much smaller size just to treat the water that fills into the dishwasher. The salt goes into a separate reservoir in the machine. There's no place to put salt into a dishwasher unless it has a built-in water softener. The salt is used to create brine (salt water) to refresh the resin bed in the water softener mechanism. The salt water flushes through the resin bed then goes to the drain. This process is called regeneration. It occurs on a specific schedule determined by the dishwasher, not every time the machine runs. The dishes are never exposed to salty water. Adding salt to a dishwasher that doesn't have a water softener built-in, by just sprinkling it into the tub or adding it with the detergent will do absolutely nothing useful. |
Post# 1091947 , Reply# 10   10/4/2020 at 15:15 (1,292 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 1091950 , Reply# 11   10/4/2020 at 15:34 (1,292 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1091998 , Reply# 12   10/4/2020 at 23:18 (1,291 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
A BI water softener can be nice if you have hard water, it allows you to get great results without buying the more expensive detergents. It really does not matter what kind of salt you use in the softener as long as it is for a water softener.
In reality it is better to direct wire a DW, less chance of the outlet under the sink or the connection at the DW overheating and failing or even causing a fire.
One ice thing on Bosch DWs is they have an On-Off button on the control panel that cuts off all power when you are not using the DW, you could also cut off the breaker for extended absence.
Post# 1092110 , Reply# 13   10/5/2020 at 20:20 (1,290 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
