Thread Number: 84717
Wax Motor Dissection |
Post# 1091683   10/2/2020 at 16:24 (1,273 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1092484 , Reply# 1   10/8/2020 at 22:06 (1,267 days old) by chetlaham (United States)   |   | |
Post# 1092542 , Reply# 2   10/9/2020 at 07:00 (1,267 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 1092579 , Reply# 3   10/9/2020 at 13:06 (1,266 days old) by RP2813 (Sannazay)   |   | |
Given his accent, are we to assume this motor is out of something other than a Maytag? I have not heard of wax motors other than the trouble they caused with Maytag's early Neptune models.
Also, is it safe to assume that by now any Neptunes still in use that were originally equipped with these motors have had them replaced? I ask this because my MLG2000AWW stacked pair is 16 years old and while I'm thinking the washer's original wax motor must be ancient history, the door's locking and unlocking process is silent, so that has me wondering. |
Post# 1092602 , Reply# 4   10/9/2020 at 15:15 (1,266 days old) by DADoES (TX, U.S. of A.)   |   | |
Regards to appliances ... some dishwasher rinse aid dispenser incorporate wax motors. Fisher & Paykel used one for the recirculation diverter valve on EcoSmart toploaders for years, until IIRC one of the engineering revisions changed the pump to the SmartPump that AquaSmart/HE toploaders use which involves a passive flapper for flow direction control. There may be others. |
Post# 1092792 , Reply# 5   10/10/2020 at 22:55 (1,265 days old) by SudsMaster (SF Bay Area, California)   |   | |
Um my Neptune MAH7500 is about 20 years old and the wax motors are still working just fine. Mostly I can hear them for the door lock/unlock. I don't know if they are used for the water valves. But there's not problem with that, either, I'm guessing wax motors are more reliable and longer lasting than solenoids. They are also slower, but in a wash cycle that already can take well over an hour, not a big issue.
Or did I misinterpret something? Wouldn't be the first time. |
Post# 1092797 , Reply# 6   10/10/2020 at 23:25 (1,265 days old) by DADoES (TX, U.S. of A.)   |   | |
Wax motors are not used for water inlet valves due to the slow motion they produce. Early Neptunes used them for the bleach and softener dispenser, IIRC. MAH7500 door lock may have had the updated wax motor design from the beginning of production, to the point that it was changed to a solenoid. RJ's MAH6500 has a solenoid for the door lock. |
Post# 1092800 , Reply# 7   10/11/2020 at 00:45 (1,265 days old) by SudsMaster (SF Bay Area, California)   |   | |
Post# 1092814 , Reply# 8   10/11/2020 at 06:25 (1,265 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
~1998 E'lux FLs have both solenoid and wax on the door latch. Solenoid is latched any time machine is on. But you can switch it off and open/add items as long as it is in the 'tumble' range. Wax is only on for spin, so door stays latched for a l-o-o-o-n-g time after powered off. Bother if you have to redistribute for balance; that didn't happen all that often. |
Post# 1092832 , Reply# 9   10/11/2020 at 10:42 (1,264 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
