Thread Number: 84762
Maytag mvwp575gw ATC. Not sure if this is a victory or not? |
Post# 1092236 , Reply# 2   10/6/2020 at 21:54 (1,295 days old) by Yogitunes (New Jersey)   |   | |
on the Cabrios....I found it best to remove the restrictor on the HOT side....
leave the sensor in place.... and have the water heater set at least to 140...mine is set at 160.... models may vary with programming, but even with mine dubbing down the hot side 10 degrees, it was still a hot wash.....even WARM was at a good setting... factor in too, your most likely starting with a cool washer, and the clothes are probably cool/room temp...your taking a temp drop there as well....and your only talking a few gallons on HE machines, versus traditional TLers using upwards of 21 gallons.... YMMV |
Post# 1092588 , Reply# 4   10/9/2020 at 13:56 (1,293 days old) by panasonicvac (Northern Utah)   |   | |
