Thread Number: 84806
/ Tag: Modern Dishwashers
Wash pump running while draining |
Post# 1092657   10/10/2020 at 03:32 (1,287 days old) by chetlaham (United States)   |   | |
Post# 1092659 , Reply# 1   10/10/2020 at 03:41 (1,287 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
grease.... |
Post# 1092696 , Reply# 2   10/10/2020 at 09:44 (1,286 days old) by chetlaham (United States)   |   | |
Post# 1092732 , Reply# 3   10/10/2020 at 14:40 (1,286 days old) by Yogitunes (New Jersey)   |   | |
Post# 1092735 , Reply# 4   10/10/2020 at 14:50 (1,286 days old) by chetlaham (United States)   |   | |
Post# 1092737 , Reply# 5   10/10/2020 at 14:58 (1,286 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Yep... A tricke of water helps pushing the oil film to the drain. |
Post# 1092749 , Reply# 6   10/10/2020 at 16:08 (1,286 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
potscrubber dishwashers did this too, even when filling. |
Post# 1092928 , Reply# 7   10/12/2020 at 09:56 (1,284 days old) by vacerator (Macomb, Michigan)   |   | |
model year GE Profile does it for about 30 seconds on the pre wash drain. |
Post# 1092970 , Reply# 8   10/12/2020 at 18:05 (1,284 days old) by chetlaham (United States)   |   | |
Post# 1092996 , Reply# 9   10/12/2020 at 20:21 (1,284 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Older Whirlpools did the filling when the pump was in wash mode. I like that so that the dishes start to get drenched. I love the sounds of the pump gathering strength. |
Post# 1092999 , Reply# 10   10/12/2020 at 20:34 (1,284 days old) by iej (.... )   |   | |
I seem to remember older Siemens dishwashers doing that here.
Post# 1093002 , Reply# 11   10/12/2020 at 20:54 (1,284 days old) by appnut (TX)   |   | |
Post# 1093025 , Reply# 12   10/13/2020 at 04:51 (1,284 days old) by chetlaham (United States)   |   | |
Whirlpool machines seem to start half way through the fill. Never understood why but its interesting to hear the pump gather strength.
@Appnut- My Maytag is the same. The pump does 2-3 short bursts then stays on. I know why but don't know physics behind it. When you start the drain pump on a full tub of water the amount the comes out of the drain hose is small, but if you pulse the pump its seems to trigger almost a siphon or something because its start to drain like you would expect- fast. |
Post# 1093052 , Reply# 13   10/13/2020 at 10:35 (1,283 days old) by DADoES (TX, U.S. of A.)   |   | |
My dishwasher has a reversing pump motor with separate impellers on the one shaft for wash and drain. The spray arm sits directly atop the upper recirculation impeller. The lower drain impeller is in a small sump. Current draw on the motor is used to sense the proper fill level so it must run the pump during fill. It runs the pump on an approx 15- to 20-second cycle (I haven't timed it exactly) for an approx 3-min drain period (I haven't timed it exactly) with momentary little pulses during the dwells. |
Post# 1093101 , Reply# 14   10/13/2020 at 19:07 (1,283 days old) by chetlaham (United States)   |   | |
