Thread Number: 84820
Door Lock |
Post# 1092849   10/11/2020 at 14:24 (1,292 days old) by chetlaham (United States)   |   | |
Post# 1092856 , Reply# 1   10/11/2020 at 15:33 (1,291 days old) by easy (Boston, Mass)   |   | |
My LG FL locks at some point during the fill cycle. The "Add Garment" which would unlock the door refuses to do it once a certain amount of water has entered the tub. I assume this is so no water can spill on the floor when the door is opened. |
Post# 1092867 , Reply# 2   10/11/2020 at 16:49 (1,291 days old) by chetlaham (United States)   |   | |
Post# 1092870 , Reply# 4   10/11/2020 at 17:34 (1,291 days old) by chetlaham (United States)   |   | |
Post# 1092932 , Reply# 6   10/12/2020 at 10:23 (1,291 days old) by Golittlesport (California)   |   | |
My LG 3570 locks the door as soon as you press "start." When you hit "pause" the machine stops and the door unlocks. You can unlock and open the door anywhere in the cycle. The door does not unlock during spin until the tub stops rotating. Also, as others noted, when it has heated the water it will not unlock door when hot water is in the tub.
Post# 1092938 , Reply# 7   10/12/2020 at 11:32 (1,291 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
a Duet clone. Locks the door as soon as you press start. If you need to add clothes during the add portion of the cycle, you press pause and the door will unlock providing the water level is not too high, or water temp too hot. If either of these conditions occur it will not unlock until a drain and in the case of too hot it will add cold water to the clothes before unlocking.
Post# 1092992 , Reply# 8   10/12/2020 at 20:10 (1,290 days old) by petek (Ontari ari ari O )   |   | |
Post# 1092993 , Reply# 9   10/12/2020 at 20:15 (1,290 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
will lock the door a few seconds after you start it. However, you can pause the cycle to add a garment or to observe the water level. The water has to be at a safe level and temp. |
Post# 1092995 , Reply# 10   10/12/2020 at 20:18 (1,290 days old) by qsd-dan (West)   |   | |
