Thread Number: 84830
Speed queen washer awn432sp111tw01sooo loud |
Post# 1093115 , Reply# 2   10/13/2020 at 22:07 (1,284 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It is probably a bad top spin bearing, do try popping the pump off the motor and running it if you like, but pumps don't make noise unless something is in the pump and it would make noise while agitating.
If it is the top bearing it is difficult to replace, it may run for a long time without failing.
You could try turning the machine up-side-down and soaking the bottom of the bearing with oil and leave it USD for at least a few days.
If the washer was stored in a very humid place or if water was left sitting the the outer tub this type of failure is more likely during long storage.
