Thread Number: 85122
/ Tag: Modern Dryers
Dryer exhaust pipe location |
Post# 1096343 , Reply# 1   11/8/2020 at 06:52 (1,257 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1096355 , Reply# 2   11/8/2020 at 08:23 (1,257 days old) by ramm440 (Arizona)   |   | |
I sorry, I probably wasn’t clear so I am looking for a Rear Left exhaust. My current dryer has a Rear Center exhaust hooked in through rectangular periscope type connection to get it over to the left. |
Post# 1096367 , Reply# 3   11/8/2020 at 10:25 (1,257 days old) by DADoES (TX, U.S. of A.)   |   | |
Probably none. My exhaust is also too close to the left, at a corner (straight shot out an exterior wall). I can't shove the dryer into the left wall to center it on the exhaust so I have it set at an angle. Otherwise the ducting is flexed at a sharp offset which obstructs the airflow enough to be a problem. |
Post# 1096369 , Reply# 4   11/8/2020 at 10:27 (1,257 days old) by jaums (Silver Spring, MD 20906 USA)   |   | |
Would a flat, adjustable-length vent work for you? Most say something like adjustable between 24 inches to 41 inches--seems to me it could be cut down to shorter if need be. CLICK HERE TO GO TO jaums's LINK |
Post# 1096371 , Reply# 5   11/8/2020 at 10:59 (1,257 days old) by Yogitunes (New Jersey)   |   | |
those periscope vents come in a variety of sizes, can be cut, and flipped for both ports to exit the same direction, as in it will get you to the corner, and then additional piping would connect it to the outside vent....the configurations can be endless for a number of applications...
one dryer I used it on had a flat back, so I removed one of the ports and fastened it direct to the machine... |
Post# 1096399 , Reply# 7   11/8/2020 at 12:54 (1,257 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Reply # 1, Thats what I was suggesting a vent that goes out the left side.
If you want the dryer tight to the side wall you may have to dissemble the dryer and pull the aluminum flex into the machine and then connect it.
You can not move the machine without taking the machine apart, I did one of these hook-ups a few weeks ago in a kitchen and I screwed the machine to the floor so no one could move it and destroy the duct connection.
Post# 1096409 , Reply# 8   11/8/2020 at 13:57 (1,257 days old) by Yogitunes (New Jersey)   |   | |
I even seen set-ups where they built a platform for the dryer sit on, and vented out the right, down under the platform, and out the left hand side for connection to the outside....
you might even find raising the dryer giving you better access for loading/unloading with less bending... anything is possible.... |
Post# 1096470 , Reply# 9   11/9/2020 at 01:45 (1,256 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 1096478 , Reply# 10   11/9/2020 at 03:21 (1,256 days old) by chachp (North Little Rock, AR)   |   | |
Last June we were buying a new Washer and Dryer. I was considering a ventless electric dryer and the stories told here about 3 hour drying times and who knows what else almost gave me pause but I went with it anyway because this best suited my needs in the laundry room. Well I have seen none of these issues and I am very happy with it.
Is that an option for you? Mine can be pushed almost all the way against the wall. |
