Thread Number: 85182
/ Tag: Vintage Dishwashers
Australian 1965 Frigidaire Deluxe Dishwasher |
Post# 1096969   11/13/2020 at 19:32 (860 days old) by mit634 (Sydney)   |   | |
![]() 2
Hello everyone,
It's been a long time since I last posted on here. I've recently picked up a few interesting appliances. The most recent is a Frigidaire Deluxe spin tube era dishwasher. The model number is DWDU5. The schematic is dated June 1965. It's in beautiful condition. The chrome on the front is pristine and has no pitting. The markings on the timer dial are not worn and there is no water staining inside. It must have had minimal usage. Comparing with pictures and literature of American models, it appears to have features of both the Custom Imperial (the front trim and the wire cutlery basket) and the Deluxe (no detergent dispenser). I have connected it to power and advanced it through the cycle and everything appears to operate. Next step will be to add water. I've read here on AW that leaking gaskets can be a problem with these dishwashers, but I can make replacements. It's exciting to have a vintage Frigidaire dishwasher to go with my Frigidaire Flair range and Frigidaire Custom Deluxe Frost Proof refrigerator. At some point I intend to use all three to create a vintage all-Frigidaire kitchen. |
Post# 1096970 , Reply# 1   11/13/2020 at 19:33 (860 days old) by mit634 (Sydney)   |   | |
Post# 1096971 , Reply# 2   11/13/2020 at 19:34 (860 days old) by mit634 (Sydney)   |   | |
Post# 1096972 , Reply# 3   11/13/2020 at 19:35 (860 days old) by mit634 (Sydney)   |   | |
Post# 1096974 , Reply# 4   11/13/2020 at 19:51 (860 days old) by Tomturbomatic ![]() |
Have fun and thanks for sharing. |
Post# 1097007 , Reply# 5   11/14/2020 at 06:50 (860 days old) by Jetcone ![]() |
Post# 1097009 , Reply# 6   11/14/2020 at 07:01 (860 days old) by steved ![]() |
The fact that the dial says "Dishmobile" indicates it was converted to a built-in unit. It looks exactly the same as the one I had, with the exception of the interior color. Question is, why doesn't it say "product of general motors holden's"?
Post# 1097013 , Reply# 7   11/14/2020 at 07:57 (860 days old) by combo52 ![]() |
![]() 3
![]() Thanks for sharing it with us Tim.
I love the blue interior, it is interesting that the timer knob says Dishmoble as it does not show any signs that it ever had wheels on it etc. I guess if you looked up the model # you could really tell if it was once a portable or if someone either put the wrong knob on it or replaced it with the wrong knob.
I guess it says Product Of General Motors even thought it was built by the Holden division because the Holden was part of General Motors.
Post# 1097016 , Reply# 10   11/14/2020 at 08:35 (860 days old) by Steved ![]() |
![]() 2
Thank you for the explanation, that makes a lot of sense. |
Post# 1097017 , Reply# 11   11/14/2020 at 08:47 (860 days old) by gansky1 ![]() |
Post# 1097027 , Reply# 12   11/14/2020 at 10:17 (860 days old) by Unimatic1140 ![]() |
Post# 1097050 , Reply# 13   11/14/2020 at 13:16 (859 days old) by Mickeyd (Hamburg NY)   |   | |
![]() 4
Four leaks stopped by a long bead of marine sealant and a shark bite for the supply thanks to lover boy, and I was in business. Good luck on yours; spintubes are a ball !
Post# 1097056 , Reply# 14   11/14/2020 at 13:53 (859 days old) by panthera ![]() |
Post# 1097146 , Reply# 15   11/15/2020 at 13:07 (858 days old) by Hippiedoll ( arizona )   |   | |
Post# 1097280 , Reply# 16   11/16/2020 at 14:11 (857 days old) by mit634 (Sydney)   |   | |
![]() 3
Thanks so much everyone for the comments, advice, pics, brochure and overall enthusiasm !
I was similarly intrigued that the front panel does not say "General Motors Holden's" as is usual for vintage Frigidaire appliances here. Also that the timer dial refers to it being a "Dishmobile" even though it is an under counter model. I came to the same conclusion that @gizmo states - dishwashers were not commonplace here at the time and so rather than tooling up to manufacture the whole machine, many parts were imported from the USA. And to minimize inventory, all dishwashers were designated Dishmobiles. Looking through advertisements of the era in digitised newspapers online, it seems Frigidaire offered only two models here in a single "Deluxe" line: an under counter and a mobile unit. Looking forward to posting more updates here. |
Post# 1097834 , Reply# 17   11/21/2020 at 15:20 (852 days old) by mit634 (Sydney)   |   | |
![]() 2
Hi Everyone,
Yesterday I connected the dishwasher to the garden hose to test it running through a cycle. Everything seemed to operate as it should, even the fill valve, remarkably. The only leaks noticed so far are where the heating element enters the bowl at the bottom and where the spray head enters at the top. It's a very pleasant sounding machine and the drain solenoid makes an impressive "clack' when engaging. I love the way the timer slowly but confidently creeps to the next segment, rather than jumping quickly, as many other timers do. Here is a video of its inaugural run. |
Post# 1097849 , Reply# 18   11/21/2020 at 17:20 (852 days old) by Steved ![]() |
I love the clear markings on the timer dial. Mine is a little worn and faded. Enjoy! |
Post# 1097862 , Reply# 19   11/21/2020 at 18:44 (852 days old) by Jetcone ![]() |
![]() Wow we always love our solenoid drive machines the best !!
Chris , thanks for the explanation of Dandenong, I would guess they produced the washers there too??
Post# 1097863 , Reply# 20   11/21/2020 at 18:49 (852 days old) by bajaespuma ![]() |
Post# 1097916 , Reply# 21   11/22/2020 at 02:35 (852 days old) by mit634 (Sydney)   |   | |
Post# 1097924 , Reply# 22   11/22/2020 at 06:32 (852 days old) by panthera ![]() |
![]() 3
![]() I have always been fascinated by how little these machines have changed through the years. Modern ones made in the US use much less water and only in very recent years have the top of the line models begun to clean (in several hour cycles) half as well as the BOL GE/Hotpoint/Magic Chef models of the mid-80s did in less than an hour.
One reason GM wanted to hang on to German Opel during their bankruptcy was because Opel, like Holden, was a gigantic source of much of their more advanced technology.
Americans are so busy telling themselves they lead the world in everything they have trouble believing anyone else might be doing things better. GM, despite their many, many, many failings, at least has the sense to exploit better technologies when their 'foreign' holdings offer them. |
Post# 1097951 , Reply# 23   11/22/2020 at 10:57 (852 days old) by appnut ![]() |
Tim, thank you for providing us with a video. Yes, these dishwashers have a very soothing, calming sound when they're going through the spray/circulation portion of each cycle. Every family I know who had a Frigidaire spin tube dishwasher had the drained water eing sent through the side port of the garbage disposal. This was the only dishwasher that expelled water with such intense force that the water would bubble up to the top of the disposal by the time the drained water stopped. I knew it had to have produced a very forceful wash spray. I used to fantasize that Frigidaire would some how manage to simply ad a revolving spray arm at the bottom still maintain the rest of the washing action. Always thought it would have been a powerhouse of a dishwasher with unlimited loading flexibility.
Post# 1098014 , Reply# 24   11/22/2020 at 16:56 (851 days old) by panthera ![]() |
![]() It's a bit like the bottom wash-arm only KitchenAids - you look at them and ask yourself how on earth they couldn't see the need for a top sprayer?
Or the first Frigidaire (Electrolux) dishwashers which had a little ball designed to gunk up within two washcycles and stop working, thus making an otherwise really clever system worse than useless.
Or...well, sometimes I think there is a level of middle-management involved who are the epitome of the Peter Principle. |
Post# 1098053 , Reply# 25   11/22/2020 at 22:47 (851 days old) by chetlaham ![]() |
Post# 1098093 , Reply# 27   11/23/2020 at 12:10 (851 days old) by vacerator (Macomb, Michigan)   |   | |
plant is a mall now. Woodville was the first plant. It built Chevrolet, Pontiac, and some Olds ckd cars, then the first Holden 48/15 FE. which was conceptualized as a compact Buick. |
Post# 1098410 , Reply# 32   11/26/2020 at 16:01 (847 days old) by jamiel ![]() |
That was the original plan with the 2016 product plan to stop assembling in AU and bring in the Commodore from Germany, the Cruze from Korea or Thailand, the Acadia from Spring Hill, the Equinox from CAMI (or Mexico) and the pickup trucks from Thailand...then the plan to sell Opel made the FWD Commodore non-viable long term; but they still had hope that they could short term the Commodore and then do a de-contented CT6 as the "new Commodore". Then the Commodore/Insignia bombed in the AU market (did much better in NZ, actually), and the Equinox didn't appeal at all (these were expected to be the two volume sellers). With these two market failures, they entered a RHD death spin (where without UK business volume, without a South Africa plant, with essentially no Japan market, and a very underutilized Thailand plant the business in AU/NZ became unviable. I was at OnStar during this period--we were anticipating launching down there in AU/NZ (had staffed up planning/public safety outreach) down there because OnStar was finally a viable worldwide product (with 4GLTE you could use a single type hardware worldwide). I've got lots of details, actually, as I was very involved in the AU launch, but unfortunately when the Commodore/Equinox bombed the expansion was placed on hold, then killed off.
Post# 1098417 , Reply# 33   11/26/2020 at 18:28 (847 days old) by luxflairguy ![]() |
![]() 3
I thought this thread was about Australian Frigidaire dishwashers NOT about cars? Am I wrong? Trust it to Mike (Vaceartor) to re-direct the thread! |
Post# 1098418 , Reply# 34   11/26/2020 at 18:32 (847 days old) by eronie ![]() |
Ok how does the spin tube work? Spin on it's own? Pix and vids please! |
Post# 1098428 , Reply# 35   11/27/2020 at 00:18 (847 days old) by appliguy ![]() |
![]() 3
in post # 29 he also got wrong two pieces of information regarding the ElCamino. First off it the 1959 and 1960 models were NOT based on the Impala they were based on the BOL 2 door Chevrolet station wagon and second, production of the ElCamino stopped after the 1988 model year NOT 1985. PATRICK COFFEY
Post# 1098571 , Reply# 37   11/28/2020 at 17:04 (845 days old) by panthera ![]() |
![]() 4
![]() Dahlings, we've always wandered all over the place in these threads and somebody has always been upset about it...and yet, we still all wander. It's not that big of a deal. Really - that Holden and Frigidaire both belong to a now dead era of GM's Mark of Excellence is relevant. That Frigidaire today is...well, we don't use those words on Imperial and GM can't seem to produce anything which doesn't have at least 17 recalls is tragic enough. I, for one, welcome references to that wonderful past.
Post# 1098578 , Reply# 38   11/28/2020 at 17:38 (845 days old) by vacerator (Macomb, Michigan)   |   | |
![]() 4
Panthera! for not turning me into a goat, or pigeon. |
Post# 1098641 , Reply# 39   11/29/2020 at 07:12 (845 days old) by gizmo ![]() |
![]() 2
Or turning me into a kangaroo... ;) |
