Thread Number: 85205
/ Tag: Modern Dryers
Are these new Roper or new Whirlpool dryers any good? Which is better? |
Post# 1097245 , Reply# 1   11/16/2020 at 11:05 (1,228 days old) by DADoES (TX, U.S. of A.)   |   | |
Those are the same dryer with different control panels/features. Top-filter design that Whirlpool has been producing since the mid 1960s. Both have thermostatic auto-dry, which determines dryness level via the exhaust air temperature. The timer does not advance on the auto-cycles when the heating element is on, does advance when it cycles off. Evaporating moisture keeps the air temperature down when the load is wetter at the start so the heater runs more to reach and maintain the temperature, the timer runs less. The heat runs less and the timer more as the load progresses toward dryness. Thus the cycle time automatically varies per the heating characteristics of a given load. Timed dry is also an option. The Roper has two temperature choice integrated into the timer. Low heat is available only on the Automatic Dry Low Heat cycle, not on Timed Dry. It has an extended tumble function on the Automatic Dry High Heat cycle (which continues tumbling in cool air for a period of time to avoid wrinkles from the load sitting stationary in the drum). Does not have an end-of-cycle buzzer. The Whirlpool has a separate temperature selector for Low, Med, and High ... which allows any temperature to be used on any timer cycle. One Automatic Dry cycle, one Timed Dry cycle, and timed Air Fluff. The Automatic Dry cycle has extended tumble. End-of-cycle buzzer that can be turned on or off. A better choice is a model with moisture-sensing auto-dry. A low-voltage electric circuit on the Automatic Dry cycle(s) operates via a pair of metal bars in the drum. Wet/damp clothes brushing against the bars repeatedly stall and run the timer until the cycle advances to off, thus sensing the moisture of the load directly instead of indirectly via the air temperature curve. |
Post# 1097251 , Reply# 2   11/16/2020 at 11:52 (1,228 days old) by ea56 (Cotati, Calif.)   |   | |
I’ve owned and been using a BOL Maytag electric dryer that I bought new at Lowes 5 years ago. It is pretty much the same as the Whirlpool dryer that you are considering. This dryer is great! Dries fast and accurately, I almost never have found any damp spots when the load is complete and most full loads dry in about 35 mins on high.
I know I may be in the minority here on this site, but I personally prefer the thermostatic auto dry system in an electric dryer over the moisture sensor controlled auto dry systems. I’ve owned and used several of each type and have never been satisfied with moisture sensor auto dry, I’ve found that they usually cycle off prematurely before everything is completely dry, are slower to cycle off and result is frustration, wasted time and electricity. So I’ll never purchase one of this type again, as long as the thermostatic auto dry models are being sold.
If you are a no nonsense type of user that doesn’t require med temp. I’d go with the Roper, but I’m sure you’ll be happy with either of the options you’re considering.
Eddie |
Post# 1097263 , Reply# 3   11/16/2020 at 12:29 (1,228 days old) by DADoES (TX, U.S. of A.)   |   | |
Thermostatic auto-dry works reliably and consistently when the machine is in an indoor environment not subject to wide seasonal temperature swings. Ours installed an an unheated/uncooled garage suffered a wide disparity in performance between summer underdrying and winter overdrying due to cold input air causing longer heating times and faster cooling between heat cycles (during which time moisture is still evaporating from the load). This post was last edited 11/16/2020 at 14:41 |
Post# 1097273 , Reply# 4   11/16/2020 at 13:08 (1,228 days old) by appnut (TX)   |   | |
Since they are basically the same dryer, I'd go with the Whirlpool because it's 7.0 cu. ft. and has more flexibility, particularly with regards to temp choice as well as being auto dry cycle. 6.5 cu. ft. is too small for any of today's dryers. That capacity was best suited for standard Whirlpool and Kenmore washers from the mid 1960s until the large capacity models became mainstream in 1976. I have a 26 y/o Maytag that's the same 6.5 capacity, if not 6.2 cu. ft., It's noticeably smaller than the 6.7 cu. ft. 1986 Lady Kenmore dryer it replaced. And I've had the Maytag for 26 years. A full load in my 1986 Lady Kenmore driect drive washer was pushing the capacity of the Maytag. especially when dealing with stuff you want few wrinkles. I need a 7 cu. ft. dryer, if not 7.4 cu. ft., but I won't get rid of the Maytag until it croaks. I have to split very large loads of towels into 2 ryer loads. Drives me nuts.
The 3 dryers I've had since 1978 have all featured electronic moisture sensors in the drum and it's all I will have. My partner has the Amana version of the Roper dryer you are considering and it just doesn't possess the accuracy I'm accustomed to all these years. He also notices the difference in the performance between my dryer and his dryer when laundry is done at my house. |
Post# 1097374 , Reply# 7   11/17/2020 at 10:20 (1,227 days old) by Yogitunes (New Jersey)   |   | |
there are used dryers, and used appliance stores in abundance....much to choose from....
CLICK HERE TO GO TO Yogitunes's LINK on Atlanta Craigslist
Post# 1097375 , Reply# 8   11/17/2020 at 10:21 (1,227 days old) by Yogitunes (New Jersey)   |   | |
Post# 1097376 , Reply# 9   11/17/2020 at 10:22 (1,227 days old) by Yogitunes (New Jersey)   |   | |
Post# 1097377 , Reply# 10   11/17/2020 at 10:34 (1,227 days old) by Ct (georgia)   |   | |
Thanks for the links...but I'm in Athens...it does seem as if a lot of washer dryers are available just south of Atlanta.....I saw the old Kenmore, and if it was closer, would have looked at it....or if I had a truck or van..... |
Post# 1097402 , Reply# 11   11/17/2020 at 13:56 (1,227 days old) by Ct (georgia)   |   | |
Anybody know what brand this dryer is?
Post# 1097404 , Reply# 12   11/17/2020 at 14:03 (1,227 days old) by appnut (TX)   |   | |
Post# 1097405 , Reply# 13   11/17/2020 at 14:06 (1,227 days old) by Ct (georgia)   |   | |
Would it be large enough for two person household? Could it do blankets? Someone is giving it away.....assuming it's still there.....Can you tell the age from the picture, or an estimate? |
Post# 1097407 , Reply# 14   11/17/2020 at 14:10 (1,227 days old) by appnut (TX)   |   | |
Post# 1097408 , Reply# 15   11/17/2020 at 14:16 (1,227 days old) by ea56 (Cotati, Calif.)   |   | |
My family had a Whirlpool dryer this size, only about 10 years older. We dried everything in it, blankets included, because it was the only game in town.
Incidentally, that dryer sat out on the back porch, exposed to the weather on three sides and served us for 20 years with only a belt replacement and a new element after about the first 10 years of use. And for about a year, when my stepfathers family lived with us it dried the laundry for a household of TEN people.
I’m sure that if it works you can make do with it for at least a little while, and maybe for quite some time. The price is right, so I’d go for it.
Eddie |
Post# 1097410 , Reply# 16   11/17/2020 at 14:18 (1,227 days old) by Ct (georgia)   |   | |
Seems a bit old.....would something that old be worth getting even if free? I imagine parts may not be available. Here's another one. It is a Kenmore but owner doesn't know year. Asking $125.00...looks like it might be ancient too.
Post# 1097413 , Reply# 17   11/17/2020 at 14:24 (1,227 days old) by appnut (TX)   |   | |
Post# 1097414 , Reply# 18   11/17/2020 at 14:58 (1,226 days old) by Ct (georgia)   |   | |
Would you buy one of these old dryers or one the new Whirlpools, if cost wasn't an issue? |
Post# 1097416 , Reply# 19   11/17/2020 at 15:19 (1,226 days old) by ea56 (Cotati, Calif.)   |   | |
If cost is not important get the new Whirlpool that you were considering at Lowes and be done with it.
It will be new with no one else’s dirt in or on it, under warranty, and large enough for any of your needs. It should also give you at least 10 years of service, with little to no trouble. Dryers, especially a basic one like this Whirlpool have little to go wrong with them. And the repairs are not that difficult or costly, unlike a washing machine.
Eddie |
Post# 1097418 , Reply# 20   11/17/2020 at 16:08 (1,226 days old) by murando531 (Augusta, Georgia - US)   |   | |
Just go with a new machine. Dryers have not changed in design in the past 30-40 years; and the whole "HE appliances don't work as well" misconception aside, there are no "HE" dryers, unless you get into condensor-heat pump models, which are still not very mainstream even today. The only thing that has really changed with dryers of all brands is having more electronic control and sensors, which are much better at reading moisture level than the simple thermistors in old machines, so you're going to get much more consistent drying without having damp or scorched crisp loads.
Not to mention that for a person or family to actually take care of an appliance and keep it cleaned inside and out is very rare in our world, so with a used machine you're going to have other people's dirt and lint buildup to have to dismantle and clean out if you don't want to risk fire. |
Post# 1097420 , Reply# 21   11/17/2020 at 16:29 (1,226 days old) by DADoES (TX, U.S. of A.)   |   | |
A few "HE" or "high-efficiency" dryers have an energy-saver function or cycle that initially heats to the target temperature, then throttles back to a lower temperature after the heat (element or gas burner) cycles off for the first time during the cycle. It may save some energy but also increases the drying time. There's a Samsung or LG (don't recall which) of which I read mention recently that runs for 45 mins without heat for some "air" drying before turning on the heat. |
Post# 1097423 , Reply# 22   11/17/2020 at 16:47 (1,226 days old) by Yogitunes (New Jersey)   |   | |
in all honesty....
if you dont have transportation to bring one home.... and dont have knowledge/experience to service/clean-up a used one... and are worried about availability of parts.... and note, there are members here, myself included, who have jumped states to grab a machine, or had it shipped from across the country..... your best bet, save yourself the headache and purchase a new one! |
Post# 1097431 , Reply# 23   11/17/2020 at 17:04 (1,226 days old) by appnut (TX)   |   | |
Post# 1097432 , Reply# 24   11/17/2020 at 17:07 (1,226 days old) by appnut (TX)   |   | |
Post# 1097435 , Reply# 25   11/17/2020 at 17:11 (1,226 days old) by ea56 (Cotati, Calif.)   |   | |
I had one of those LG dryers, what a piece of crap! The only way that I found I could get high heat and dry a load in a reasonable amount of time was to use the timed dry cycle, bypassing the moister sensor for auto dry.
The first load I dried in it on the Normal/Cotton cycle took 90 freakin minutes, because of the “Energy Saving” setting of this cycle, and on top of that ridiculous cold air, no heat portion of the cycle the highest heat it would use on any preset cycle was Med. WTH! How about some GD sanity saving!
Eddie |
Post# 1097443 , Reply# 26   11/17/2020 at 17:47 (1,226 days old) by qsd-dan (West)   |   | |
I'd personally buy the older one, it's much better built.
The final answer: If you're handy with tools and have diagnostic skills, buy the old dryer, tear it down, clean/rebuild, and enjoy the fruits of your labor. Just be on the lookout for a spare timer on ebay since they are NLA at this age. If you just want the damn thing to work (for a little while, anyway), purchase a new dryer. |
Post# 1097444 , Reply# 27   11/17/2020 at 17:48 (1,226 days old) by Ct (georgia)   |   | |
The buy new consensus won. Just bought the Whirlpool dryer - will go with the 18 year old Kenmore washer.....Thanks everyone for your help and advice. |
Post# 1097454 , Reply# 28   11/17/2020 at 19:16 (1,226 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1097457 , Reply# 29   11/17/2020 at 19:31 (1,226 days old) by ea56 (Cotati, Calif.)   |   | |
