Thread Number: 85209  /  Tag: Vintage Automatic Washers
Indesit 850W Washing Machine - Need urgent help and expertise!
scroll >>> for more items
Post# 1097286   11/16/2020 at 14:55 (855 days old) by Washerman20 (Cardiff)
Hi there,
I hope this is the right place to ask this but I have a feeling that it is. We have moved into hospital accommodation (doctors who live on site) and we have an old Indesit washing machine in the accommodation. The washing machine functions (albeit leaks a little) but it does not have a proper control dial. We're currently trying to figure out the orientation but trial and error can take quite some time with this kind of thing! Is anyone able to help with the following?
Where in relation to the flat side of the control pin would the "arrow" point?
The machine seems to stop without draining, but can drain if you set it to another setting, is this normal? I.e. does it normally do a wash cycle that you then restart as a drain cycle?
Many thanks,
Washerman
Post# 1097301 , Reply# 1   11/16/2020 at 16:46 (855 days old) by Rolls_rapide (.)
I'm assuming that the programmes you selected were ones with built in 'rinse hold' such as 'delicates'?
If so, then yes, the machine is supposed to stop full of cold water on the final rinse (to prevent creasing of synthetic fabrics).
To get a full programme wash-rinse-spin, you would have to select one of the 'cottons' programmes:
2 White Cotton @ 90°C, (white cotton and linen items)
3 Fast Coloureds @ 60°C, (colour-fast dyed fabrics, little bleeding of the dyes such as coloured towels),
4 Non-Fast Coloureds @ 40°C (non-colour-fast items which bleed/transfer dyes readily, such as coloured t-shirts).
Regarding the orientation of the shaft... I suppose you could try rotating the dial to find '13: Drain, No Spin'. Basically, only the drain pump should activate for a few minutes, and then stop by itself. There shouldn't be any water filling or spinning, but I don't know if there might be a gentle tumble as it empties.
Post# 1097305 , Reply# 2   11/16/2020 at 17:33 (855 days old) by Vacbear58 (Sutton In Ashfield, East Midlands, UK)
Indesit washer
vacbear58's profile picture
as noted above the stop before spin is normal on delicates, if there was a knob it would be aligned probably around the line between 13and14.
The best I can offer (and actually it is a good best) is to point out your posting to a member who lives is Cardiff who, if he does not have an indesit knob, most likely will have a substitute, and I am sure will be glad to help out subject to lock down restrictions
Post# 1097372 , Reply# 3   11/17/2020 at 09:52 (854 days old) by ServisChris (Southampton, Hampshire UK)
Indesit dial
servischris's profile picture
Hello. You’re in luck, I found one of these dials in a toolbox in the back of my van! Send me an email and can sort out posting. Chris
