Thread Number: 85417
/ Tag: Modern Dryers
LG DLE5977W Rollers seized for no reason. |
Post# 1099616   12/6/2020 at 18:21 (1,207 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
My dad added some anti seize lubricant for a temporary solution until I can replace the rollers. Anyone know where I can get a set of 4 for cheap? I don't want to and refuse to buy aftermarket junk. I am surprised it lasted this long. I got the unit in September and the rollers were squeaking but it worked otherwise. lasted 2 months. Serial number indicates Manufactured March 2006.
Post# 1099685 , Reply# 1   12/7/2020 at 09:43 (1,206 days old) by vacerator (Macomb, Michigan)   |   | |
lots of LG, and Samsung parts. I paid $24 2 years ago for drum rollers , belt and idler pulley kit for our Whirltag 7.3 cu. ft. dryer. The grease is a temporay fix, as lint and dust can build up and dry it out. |
Post# 1099690 , Reply# 2   12/7/2020 at 10:20 (1,206 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1099752 , Reply# 3   12/7/2020 at 22:30 (1,206 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1099762 , Reply# 4   12/7/2020 at 23:55 (1,206 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Usually you only need to replace the one that failed, the others can be cleaned and one or two drops of light oil added to the shaft [ they should not be greased ]
90% of the time the RR roller near the heater or gas burner is the one that fails, a 2006 LG dryer will not likely last long enough to put $100 worth of rollers in it.
This advice also goes for WP built 4 roller dryers, I don't think I have ever put more than one roller on one, if you clean and oil them before they seize or get noisy they will outlast the dryer.
John |
Post# 1100215 , Reply# 5   12/11/2020 at 12:35 (1,202 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1100257 , Reply# 6   12/11/2020 at 18:28 (1,202 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1101246 , Reply# 7   12/19/2020 at 21:56 (1,194 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Today I went to the used appliance store and got some more parts for free from a donor. Today I replaced the Motor,Idler pulley and the According to you John. "The cheap and flammable plastic blower housing" (Not trying to disrespect you By the way) With a metal one. I noticed many revisions on it. it removes 2 screws. The motor is also an updated motor. It is better then the original one this unit came with. Much quieter. Now I only have to wait for the rollers to wear in and I should be good to go for at least a year.
