Thread Number: 85445
/ Tag: Classified Ad Finds
Sears Timed Only Dryer |
Post# 1099973   12/9/2020 at 15:56 (1,231 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 1099977 , Reply# 1   12/9/2020 at 17:04 (1,231 days old) by warmsecondrinse (Fort Lee, NJ)   |   | |
Looks like it's been sold. Was the dryer a 120v electric? A ~24" 'apartment' sized? Those are the only dryers I've seen that have a timer dial as the sole control. |
Post# 1099984 , Reply# 2   12/9/2020 at 18:07 (1,231 days old) by CircleW (NE Cincinnati OH area)   |   | |
That is a 29" dryer, as it has the top-mounted lint filter. |
Post# 1099991 , Reply# 3   12/9/2020 at 18:57 (1,231 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 1099992 , Reply# 4   12/9/2020 at 19:03 (1,231 days old) by appnut (TX)   |   | |
Post# 1100006 , Reply# 5   12/9/2020 at 20:07 (1,231 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 1100008 , Reply# 6   12/9/2020 at 20:24 (1,231 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1100014 , Reply# 7   12/9/2020 at 20:54 (1,231 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
It is just a larger version of Whirlpool (also sold as Kenmore and Inglis) portable or stationary compact dryers that have been around for ages.
My WP compact dryer (in lovely harvest gold) is pretty much same timed drying cycles. Only difference is as above the PP has longer cool down period than normal cycle. If advertised same Whirlpool et all touted "Three Cycle" and "Cool Down Care". In some people's minds they may think that meant three different heat settings, but not a bit of it. There was just "on" heat and "no" heat as in either air dry or thermostat was satisfied and turned off heat during portions of drying cycle. All and all BOL or not, a housewife in certain instances faced with either line drying or this dryer likely would have opted for what she could get, and be happy. Don't think drying sensors and auto shutoff trickled down to even various BOL models of dryers until recent push by government mandated in name of energy efficiency. www.automaticwasher.org/c... www.automaticwasher.org/cgi-bin/... |
Post# 1100021 , Reply# 8   12/9/2020 at 21:50 (1,231 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 1100041 , Reply# 9   12/9/2020 at 23:07 (1,231 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1100060 , Reply# 11   12/10/2020 at 07:17 (1,231 days old) by easy (Boston, Mass)   |   | |
I also remember that Sears had that four cycle timed only dryer mentioned above where the air fluff cycle (30 minutes?) was a continuation of the Permanent Press cycle. They advertised this dryer as having "Wrinkle Guard". |
Post# 1100065 , Reply# 12   12/10/2020 at 08:19 (1,231 days old) by appnut (TX)   |   | |
My "other mother" had 3 dryers in 55 years. The sunburst 57 Frog Eye Kenmore. Then she got from her sister the 1960 Hotpoint all pushbutton with rapid advance timer dryer in the early 1970s. Her last dryer was a 4-cycle timed dry center dial Kenmore from the early 1980s. Her son kept this dryer, her A207, and KDS16 running until she had to move out of the house in 2012-2013.
Post# 1100067 , Reply# 13   12/10/2020 at 08:29 (1,231 days old) by appnut (TX)   |   | |
David, the Maytag 306 3-cycle dryer achieved "all fabric" status by simply having all timed dry cycles set at low heat. That was the case for their original electronic control dryers. The latter only differentiated by the wash'n'wear/perm press button dried clothes to a more dry type of scenario. Not until later 06 dryers started offering models with regular and delicate temperature buttons was the user able to select appropriate temps themselves.
Post# 1100080 , Reply# 14   12/10/2020 at 11:16 (1,231 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
All MT HOH dryers had only one operating thermostat and while it was not as hot as some brands that gave you several temperature options it certainly was not a low temperature either.
HOH dryers used 145F or 155F operating thermostats depending on their age which is much higher than the low on most dryers [ 125-135F ] that gave you a choice.
Post# 1100092 , Reply# 16   12/10/2020 at 12:19 (1,231 days old) by DADoES (TX, U.S. of A.)   |   | |
A 600 isn't BOL. "Hundreds" vs "tens" differences varies through the years but a 600 is typically like a 60 with a bit more styling or bit of feature step-up (such as the cycle signal). A 600 or 700 washer for example would possibly have A-B-C alphabet cycle designations and programmed temps on the timer (but not pushbutton) while a 60 or 70 would not be alphabet or temp-programmed. 100 or 200 would be BOL. |
Post# 1100143 , Reply# 18   12/10/2020 at 20:10 (1,230 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1100147 , Reply# 19   12/10/2020 at 20:32 (1,230 days old) by Maytag85 (Sean A806)   |   | |
Interesting thing is I put a low heat 120F in my 1973 Maytag DG306 and seems to be a bit faster with certain loads, and that could be because it holds a more steady temperature since the front of the cabinet is quite warm to the touch but as the cycle continues it gradually gets cooler to the touch and overall has a better cool down as well.
Post# 1100240 , Reply# 20   12/11/2020 at 17:34 (1,229 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1100301 , Reply# 21   12/12/2020 at 00:23 (1,229 days old) by CleanteamofNY ((Monroe, New York)   |   | |
