Thread Number: 85485  /  Tag: Vintage Dryers
Help w/ Frigidaire Gallery reversing dryer -- can't get belt back on
scroll >>> for more items
Post# 1100391   12/12/2020 at 22:31 (828 days old) by LiaVee (Ridgewood)
Hello, I am in the process of replacing the bearing assembly on a Frigidaire Gallery 1997 gas dryer with a reversing drum (Model FSG747GES1). I got the job 90% done and everything was swell until it came time to run the belt through the pulley. The dual idler pulley has two wheels and looks nothing like the pulley in the instructional videos. I've looked all over the place for a schematic or photo of something to show me how the belt is supposed to run through the two wheels. Is anyone able to help? I should have made a mental note before taking it apart!
Post# 1100407 , Reply# 1   12/13/2020 at 07:49 (828 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
Proper Belt Routing
combo52's profile picture
The belt just goes between both rollers and around the motor pulley below.,  the flat back of the belt is against the rollers and the grooved side of the belt runs on the motor pulley and against on the clothes drum.
John L.
Post# 1100408 , Reply# 2   12/13/2020 at 07:58 (828 days old) by Yogitunes (New Jersey)
yogitunes's profile picture
lets see if we can explain this.....
that pulley setup goes over the motor shaft(centered around those two half moon cutouts)...and should bolt to the motors base plate....
the belt comes between the two pulleys on the inside, and around the motor shaft...putting tension from both directions...
keep us posted on how you make out.....
Post# 1100415 , Reply# 3   12/13/2020 at 08:36 (828 days old) by DADoES (TX, U.S. of A.)
dadoes's profile picture
Not the best photo ... like this one, which is not a Frigidaire Gallery but has the same design of dual-pulley idler to handle belt tension on a reversing drum.
Post# 1100428 , Reply# 4   12/13/2020 at 10:21 (828 days old) by LiaVee (Ridgewood)
RESOLVED Help w/Frigidaire Gallery reversing dryer
It worked! Thank you all so much for the clear instructions. Well, I am off to do some laundry!!
Post# 1100435 , Reply# 5   12/13/2020 at 13:06 (828 days old) by Tomturbomatic (Beltsville, MD)
Always take a picture or two  or three before touching anything.
