Thread Number: 85554
Where is the filter hoover ecologic a3954 |
Post# 1101017   12/18/2020 at 02:45 (835 days old) by geoffacox (SUTTON)   |   | |
Hello On the fast spin 1200 setting there is a slight water leak at the base of the front of the machine? Where is the filter?! Cheers Geoff |
Post# 1101021 , Reply# 1   12/18/2020 at 05:22 (834 days old) by ozzie908 ![]() |
Post# 1101023 , Reply# 2   12/18/2020 at 05:33 (834 days old) by Ricky5050 ![]() |
Hi Geoff it doesn’t have a filter as such. There is a sump hose to pump that has a catch pot. Coins buttons etc fall in but the pump is self cleaning. If it’s leaking only on spin it might be a small hole in middle or top creases of door seal. Or soap
Powder drawer to run hose ( ie water flung up will spray out somewhere it’s wouldn’t drip out under gravity. Prob best to unplug and take top and back off and see where is wet and same underneath. Good luck Richard This photo is of earlier logic yours will have a pressure hose connection on ( which sometimes clogs with grease - and stops the machine spinning )
