Thread Number: 85612
Maytag Washer Sud Saver, Save/Drain stopped working |
Post# 1101739 , Reply# 1   12/23/2020 at 11:27 (829 days old) by combo52 ![]() |
![]() 3
Post# 1101884 , Reply# 3   12/24/2020 at 21:33 (828 days old) by Yogitunes ![]() |
the hose connecting the pump to two-way valve....pull that off....
get a connector from a hardware store...and some hose clamps as well.... now, the hose from the pump, and the hose leading to your drain....connect them two together.... valve now by-passed....remove it and tape the wires if you want to....or just leave it there..... problem solved.... some people may choose to unplug the machine while doing this....I dont, but they do! |
Post# 1102417 , Reply# 4   12/29/2020 at 15:29 (823 days old) by wonka1234 (Toronto)   |   | |
![]() 2
Just wanted to say thank you! you helped me fix it! Thanks! |
