Thread Number: 85653
/ Tag: Wringer Washers
How to operate Kenmore C960 Wringer |
Post# 1102084 , Reply# 1   12/26/2020 at 20:57 (814 days old) by Launderess ![]() |
Kenmore never built anything, it is a brand name Sears slaps on things made by others. In case of laundry appliances at that time sold in Canada there were two sources; Inglis (Whirlpool), and English Electric.
Single or dual lever controls on front of washer seem to be an Inglis/Whirlpool thing. dygtyjqp7pi0m.cloudfront.net/i/2... |
Post# 1102090 , Reply# 2   12/26/2020 at 21:33 (814 days old) by wayupnorth ![]() |
Post# 1102093 , Reply# 3   12/26/2020 at 21:38 (814 days old) by Yogitunes ![]() |
of course turning the wringer control forward or away will set the direction for the rollers to spin....
could be an all-in-one mechanism...not usually something they would hide...more of an ease of use configuration.... any chance by turning the wringer control towards the floor will allow it to pivot.?.?.?... and then turning it to point upwards to lock in place..... worth a try.... |
Post# 1102099 , Reply# 4   12/26/2020 at 22:26 (814 days old) by Launderess ![]() |
You wouldn't would you? Sears up north (Canada) often had things that weren't on offer in United States.
For variety of reasons Canadian housewives stuck with wringer washers longer than their sisters in United States. In particular just as in UK square tub wringers in a cabinet or long skirt were hugely popular in Canada. Yes, Maytag had their square tub, but that is just what it was; no cabinet. |
Post# 1102274 , Reply# 6   12/28/2020 at 06:28 (813 days old) by Launderess ![]() |
We would need closer pictures of controls to be sure but....
Am guessing knob in center of knobs is a timer or maybe speed control. Again without close-up pictures cannot be certain. Levers on left and right control agiattion (stop/start) and pump/drain respectively. There should be something printed near each stating what they do, or simply pushing/pulling back and forth will start and stop the associated action. The black knob on top of wringer likely sets tension. You twist it down to tighten, reverse to loosen. Without clear pictures of both sides of wringer head cannot say for certain, but one side there should be a switch that controls direction of rollers. One way causes rollers to move away from you, the other towards. There also should be a "strike" button or arm which is a safety device. You bang it with your hand to instantly release tension/stop rollers in case something gets caught which it shouldn't (fingers, bosom, hair, laundry....). Finally there has to be a reset button that engages tension after strike button/bar has been activated and or wringer rollers stored apart (as seen in photos above). |
Post# 1102297 , Reply# 8   12/28/2020 at 11:44 (813 days old) by combo52 ![]() |
Post# 1102302 , Reply# 9   12/28/2020 at 12:53 (813 days old) by Spudpotatohead (Phoenix)   |   | |
Here is the model tag
Post# 1102322 , Reply# 12   12/28/2020 at 17:12 (813 days old) by Spudpotatohead (Phoenix)   |   | |
No setting like that Geoff. I turn the motor on and you can hear it, but trying to turn the clutch and you just get knocking. The gears aren’t turning. |
Post# 1102324 , Reply# 13   12/28/2020 at 17:28 (813 days old) by ea56 ![]() |
![]() try moving the lever on the RIGHT labeled WASH either to the left or right until it engages then set the dial in the center to a few mins, the agitator should begin to move back and forth. The center dial is the timer which when set will cause the agitator to turn off when the time it is set for is reached. The LEFT lever is for the PUMP to empty the tub when your through washing.
The WASH lever is what engages the the motor to the transmission. The control on the left hand end of the wringer is what engages the wringer. Turn it one way to feed the the clothes through the wringer from the washing machine tub. Turn it the other way to feed the clothes through the wringer from the rinse tub.
Its really a very simple process. Play around with it for awhile to familiarize yourself with the operation of the machine.
Good luck and have fun.
Eddie |
Post# 1102329 , Reply# 14   12/28/2020 at 18:31 (813 days old) by jamiel ![]() |
Post# 1102331 , Reply# 15   12/28/2020 at 19:10 (813 days old) by ea56 ![]() |
![]() It also appears that your machine has a filter tray (the red plastic ring). This fits on top of the agitator and the end of the drain hose that fits into the hole on top of the right back side of the machine is aimed into the filter tray. With the filter tray in place aim the end of the drain hose towards the tray and engage the pump lever. The wash water will then be constantly recirculated thru the filter tray as long as the pump is on, thereby filtering the lint from the wash. This machine was a top of the line wringer washer for Kenmore.
The white bar in front of the wringer is the safety release. In case, god forbid you get a finger in the wringer hit the release bar and the tension on the wringer will be released along with your finger.
HTH Eddie |
Post# 1102339 , Reply# 16   12/28/2020 at 20:27 (812 days old) by Launderess ![]() |
Lacking an owners manual and thus working in dark so to speak, am still going with you don't know how to get wringer going rather than it being "gunked up".
These machines were built to last and take fair amount of abuse, wringer washers of all sorts sat sitting for ten, twenty, fifty or more years have started right up when plugged in. But owners knew (or soon found out) how to get things going properly. If tension isn't properly set and or safety mechanism engaged,wringers on most washers won't go no matter what one does. Maybe a long shot, but look-up long established Kenmore washer repair services in your area or adjacent. You may luck out and reach an old school person who remembers this machine and can offer assistance. |
Post# 1102351 , Reply# 17   12/29/2020 at 00:07 (812 days old) by Spudpotatohead (Phoenix)   |   | |
Thanks Eddie - I will try it with the agitator working sometime tomorrow and then report back. |
Post# 1103201 , Reply# 18   1/4/2021 at 23:15 (805 days old) by Spudpotatohead (Phoenix)   |   | |
Finally got back to the machine to try it with the motor on, agitating and the rollers still wouldn’t turn |
Post# 1106684 , Reply# 19   2/4/2021 at 05:08 (775 days old) by Launderess ![]() |
